Old 07-08-2014, 01:58 PM   #21
Originally Posted by dts3204 View Post
Not the current light fixtures for the 12DDST. Single piece plastic.
No photo, didn't happen.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 07-08-2014, 02:20 PM   #22
w4drr's Avatar
Originally Posted by BigBaron View Post
I honestly don't know where you get 14.2V from.
2.2V times 6 cells = 13.2V
Most converters don't get up to 14.2V, which is the voltage you need to properly charge some (most?) true deep cycle batteries.
3-stage converters found in most newer trailers, have a "bulk charge mode" which kicks the voltage up to 14.4V for a period of time.
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
Old 07-08-2014, 03:08 PM   #23
Phat Phrog Stunt Crew
elind's Avatar
Stupid question. Can LEDs be dimmed like 110ac light bulbs with a dimmer switch?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 07-08-2014, 04:31 PM   #24
ID:	57641Here is an interior fixture in my 12DDST
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Total (2104-2017) 319 2018 (59)
dts3204 is offline   Reply With Quote
Old 07-08-2014, 04:37 PM   #25
My interior Light uncovered
I think this is an LED Click image for larger version
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Old 07-08-2014, 04:44 PM   #26
Yes. But, you need a compatible dimmer control for led type lights.
Old 07-08-2014, 05:38 PM   #27
I think this is an LED Attachment 57643
Thanks for the photo.
Nice, yours came with an LED fixture.
Tom
2012 Rockwood A122S
Old 07-09-2014, 04:34 PM   #28
1A Camper's Avatar
Originally Posted by ko777 View Post
Does this replace the interior and external lights without any adaptor? Plug and play
Can you illustrate how to open the cover of the Aframe inside light cover?
Sorry for the long time to reply. Just got back from a month long trip in the Aframe with DW to the north west.
These were the same base as I had Interior. I have not looked at the Exteral so do not know if the base is the same. I have the 2 part, 2 Bulb, light assy in my Aframe. And they were plug and play nothing else needed.
Take a small knife and slide it between the middle bar with the switches and the lens and turn the knife so the lens will slide about 1/8 inch and then you can lift the lens off.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 07-09-2014, 04:58 PM   #29
1A Camper's Avatar
LEDs run in a range of 10~30 volts DC. How hard they are 'driven' determines how bright they are and how long they last. (quote from LED Wholesalers tech)
I recommend staying away from the cheaper LEDs. I have a whole bag full of 'em. At least they didn't cost a lot!
I think my charging unit does get up to 14.2 volts.
I know that my solar charger get up to 14.2
I know when the trailer is connected to my truck. I am running 14 volts or more.
If you run 12 volt LEDs on 14 volts they are going to have a short bright life.
I have use the above and you can run these at 10 volts or 30 volts and the light output is the same, the reason is there is a voltage regulator on the board that set the voltage to the LED that is why these are not dimable.
I do not know if you are calling these cheap or not, but I have bought 14 of these and have not had a failure in the 4 years ( 4 have only been used for 1 year) that I have use them.
Steve and Adele
2017 RB-195
Old 07-10-2014, 08:59 AM   #30
w4drr's Avatar
Residential dimmers that are LED compatible are still meant to operate on 120VAC. Unfortunately, the lighting circuit in an RV is 12VDC. That would require a special DC type dimmer.
Bob & Doris
Roanoke, VA
2013 Rockwood HW296
Old 07-10-2014, 09:09 AM   #31
elind's Avatar
Thanks!
2014 Wildcat 327ck
Old 07-10-2014, 09:00 PM   #32
As mentioned in other threads, I bought 20' of Led tape to run up and down the inside peak of the roof on drivers side, a micro dimmer switch that is wired inline to that, tapped into 12v used for the roof shutoff switch and added a lighted toggle in the bench front near the furnace ... All parts from ebay for a grand total of less that $15 delivered. At highest setting the inside is bright with indirect lighting, at it's lowest it casts a nice indirect glow like a sunset. We rarely use the ceiling lights now, the light is far better from the full length indirect.
2011 A-122
rawlus is offline   Reply With Quote
led
