Old 07-10-2014, 09:09 AM   #31
Phat Phrog Stunt Crew
elind's Avatar
Originally Posted by w4drr View Post
Residential dimmers that are LED compatible are still meant to operate on 120VAC. Unfortunately, the lighting circuit in an RV is 12VDC. That would require a special DC type dimmer.
Thanks!
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 07-10-2014, 09:00 PM   #32
As mentioned in other threads, I bought 20' of Led tape to run up and down the inside peak of the roof on drivers side, a micro dimmer switch that is wired inline to that, tapped into 12v used for the roof shutoff switch and added a lighted toggle in the bench front near the furnace ... All parts from ebay for a grand total of less that $15 delivered. At highest setting the inside is bright with indirect lighting, at it's lowest it casts a nice indirect glow like a sunset. We rarely use the ceiling lights now, the light is far better from the full length indirect.
2011 A-122
rawlus is offline   Reply With Quote
led
