Old 03-28-2016, 04:51 PM   #1
LED Lighting
I would like to switch my interior lighting over to LED. I know the size is #921. Has anybody here switched? If so, what brand should I look up on amazon.com TIA
s2111 is offline   Reply With Quote
Old 03-28-2016, 07:18 PM   #2
heavynlori's Avatar
Name:	ImageUploadedByForest River Forums1459210716.399193.jpg
ID:	103143we replaced our 921 with these
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is online now   Reply With Quote
Old 03-28-2016, 07:32 PM   #3
Ok thank you
Old 03-28-2016, 07:47 PM   #4
crunchman12001's Avatar
I switched all mine out with these. 20x Warm White T10 921 194 RV Trailer 42 SMD 12V Backup Reverse LED Lights Bulbs | eBay $19.99
These are warm white 4000-4500 kelvin. (Easy on the eyes, like incandescent)
These have 42 led's per light so they are not as bright as 921's but close. If you want brighter lights go with the 68-SMD'S.
I had 3 that blinked, the seller replaced no charge. These must be polarity sensitive, put some in one way did not work, flipped them over and worked fine. Very cool burning lights, low watt no heat.
Highly recommend.
crunchman
As far as brand...they all come from China and are rebranded.
2015 F-250 FX4
Old 03-29-2016, 08:14 PM   #5
goto superbrightleds.com and you have a choice of warm white, natural white, cool white
the 921 bulb has different light outputs, warm white the giving out the least light and cool white giving the brightest light. I got six including shipping for $29.95
royboy334 is offline   Reply With Quote
Old 04-02-2016, 12:13 AM   #6
We installed LED lighting a couple of years ago and find it pleasant. We have one warm light and one bright white in the ceiling mounted light fixtures. They work with each other to give us the best of both their worlds.
JoArt is offline   Reply With Quote
Old 04-03-2016, 04:52 PM   #7
Mountain Girl's Avatar
We want to change ours to the warmer light. In a small area the regular light is too bright. Thanks for the information on changing them.
Mountain Girl is offline   Reply With Quote
Old 04-03-2016, 05:11 PM   #8
geezer with gadgets
757Dave's Avatar
Here's an earlier thread on this same subject. Lots of good suggestions to look through...
LED 921 Upgrade
Happy travels!
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57
757Dave is offline   Reply With Quote
Old 04-04-2016, 12:05 AM   #9
Cheap Ebay LEDS mentioned in earlier post have worked for me for years.
In hallways and main areas, I use these which are brighter and throw good amount of light: 10x Warm White T10 BA15S 1156 LED 48SMD Panel Interior Dome Map RV Trailer Light | eBay
FOr areas above seating areas I use these too: 20x Warm White T10 921 194 RV Trailer 42 SMD 12V Backup Reverse LED Lights Bulbs | eBay
Only failure I've ever had was double sided tape coming undone which I fixed with 3M tape from a retail store.
Skyliner is offline   Reply With Quote
led, light
