Old 08-18-2013, 06:35 PM   #1
proskin's Avatar
LED Lighting Mod
Hi everyone. After three camping trips I decided I needed to do something with the lights. At nighttime the standard lights in the camper our way to bright. I ordered a set of warm white LED strip lights. I mounted them on the top of the wall opposite the door. I wired them in Through a switch by the front door. I then changed the single switch that lights up the floor light and put in a double higher-end switch. I can now turn on the indirect LED lighting right when I walked in the camper. The entire project cost me $30 and about two hours of work.
It creates a really nice warm white indirect lighting.
Have a great day!
ID:	38093   Click image for larger version
proskin is offline   Reply With Quote
Old 08-18-2013, 07:18 PM   #2
handbuilder's Avatar
That looks great! Way to go!
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 08-18-2013, 07:30 PM   #3
Jeep4Two's Avatar
Very similar to what I did last year. I love the light strips. The done lights rarely get turned on now, usually only to light the way to bed or quickly find something at dusk in a dark corner.
Once its dark, the led light strips provide all the light needed, and draw much less surrey than just one standard bulb, and no heat.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 08-19-2013, 07:58 PM   #4
Rockwood Premier A126
gregory's Avatar
We did that mod too and are happy with it as well!
Your double switch looks terrific!
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 08-20-2013, 06:17 PM   #5
Did you use one of the led line connector clips to wire into the tape strip or is there another method?
This dimmer control looks interesting as well....
2011 A-122
rawlus is offline   Reply With Quote
Old 08-20-2013, 06:27 PM   #6
proskin's Avatar
The LED strip I purchased had the connector built right onto it. All I needed to do was splice the red and black wire to the positive and negative through a switch. I thought about using a dimmer but decided not to. The dimmer you referenced was too big and bulky for this application. It would not have looked as nice as the simple switch. The LED brightness is perfect just the way it is. It really did not need to be dimmed that all.
Old 08-20-2013, 06:40 PM   #7
Ok cool. Thx for the info.
2011 A-122
Old 08-20-2013, 06:59 PM   #8
Found this, for under $3 figure it's worth trying.
Mini dimmer
2011 A-122
Old 08-21-2013, 09:22 AM   #9
proskin's Avatar
Links to products used in Mod!
JR Products 12145 Brown Double SPST
On-Off Switch with Bezel
Switch
16 Feet Waterproof Warm White LED Strip
3528 SMD 300LED Flexible Lamp Light 12V 2A
LED Light Strip
Old 08-22-2013, 09:23 AM   #10
gregory's Avatar
Very nice, thanks to both of you for the links.
Now this mod has Gary rethinking our install and the switch we used...
Ah, hind sight!
Deb
Deb & Gary
led, led mod, light
