07-26-2016, 12:39 PM
Led Tail Lights
Has anybody swapped out their factory tail lights for LEDS. If so what did you get? What did you have to do to modify for those type of lights. Just thinking about doing it.
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Total (2104-2017) 319 2018 (59)
07-26-2016, 12:44 PM
Friend of mine just changed out his stock tail lights for the LED's. Now this was on a smaller kayak trailer of his but the idea is the same. All he did was take off the old and put on the new. Used the same wiring. Looked good.
He just used some he bought at Wally World.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
07-26-2016, 12:46 PM
There are many threads on this issue. This is more involved than it appears on the surface. Depending on your TVs controller and the LEDs chosen, you may end up with inoperable lights. Some controllers need more current than LEDs draw to operate properly.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-26-2016, 12:53 PM
Well, I hope his still works then.
Dwayne and Susan
07-26-2016, 01:06 PM
This is what I replaced my cheap lights with. They run about $100 for a set but look & function much better. I requested a wall stud diagram from Coachman to see where the studs were. These are flush mount so I had to dremel out a larger hole since these are inset. The wiring was straight forward. The cutting of the fiberglass was the most time consuming as I cut a small finger hole and ran a clothes hanger wire to verify stud placement.
I also replaced all of the marker lights with leds. Sorry the picture doesn't save after I rotate it.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
07-26-2016, 01:51 PM
If it isnt broke . ...dont fix it.
2008 Nissan Frontier 4x4
2011 Rockwood A122
07-26-2016, 01:54 PM
.....but im impressed so much brighter they are.
Thats why have insurance....
D-mo
2011 Rockwood A122
07-26-2016, 01:59 PM
CHANGED Tail lights
I swapped the tail lights on my Rockwood fifth wheel to led lights. They are about 100 times brighter. I used a set of water proof led lights that are supposed to be used on boat trailers. They really get the drivers behind me
attention when I start to turn or stop.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2022 51 DAYS
[SIGPIC][/SI[SIGPIC]
07-26-2016, 02:05 PM
I swapped the tail lights and running lights (entire assemblies, not just the bulbs) on my 228BH to LED.
Have never heard or cannot see problems with the TV in regard to trailer lighting. Ii know when I did mine NO problems.
The computer is programmed for a specific voltage drop, so as long as the TV lights remain the same, trailer lights will not affect the computer.
That's why if you get a burned out bulb or replace your TV with LEDs and don't add a resistor, you might get a fast flashing in the turn signal circuit; the voltage drop is lower due to the burned out bulb or the replacement LED.
Etrailer is a great choice for LED replacement lights.
07-26-2016, 09:05 PM
Thanks for the info. I need to replace mine because we sometimes tow at night or in the rain. I just calculated the clearance and the brake lights must draw at least 8 amps with incandescent bulbs. With my fridge drawing 13 amps on DC, I am definitely going to get too much voltage drop when towing to keep up the charge on the camper battery, much less add to it. With LEDs and making sure I have as large a wire size on the TV as practical, I might have a chance of supporting the fridge on DC with the tow vehicle.
Fred W
2014 Rockwood A122 A-frame
2008 Hyundai Entourage (minivan)
07-26-2016, 09:26 PM
Fred W
OK, now you've confused me. And maybe I'm missing something, but bear with me.
The power for your trailer battery/fridge comes from an auxiliary power pin in your hitch receptacle, which should come from a trailer aux power fuse in your tow vehicle's fuse box (or some other fuse if you had to wire the aux power yourself). Your tail lights and brake lights are powered through 2 OTHER pins in your hitch receptacle, and should come from separate fuses in your tow vehicles fuse box (or directly from your current TV tailights if you had to wire this in yourself). This is how everybody's systems work and MOST of us have incandescent bulbs. So I don't understand what your saying about larger wires. The only other issue I've seen is that some newer cars don't have turn signal flashers, so the turn signals are turned off and on by something in the Body Control Module. This thing may not be able to handle the extra current from the TT's turn signals if they are incandescent, and therefore if you hook them up to your tail lights, there are special harnesses that have a separate power wire that hooks to your battery or something else thats "hot" and just uses the TV's turn signals as an "input" to turn your TT's turn signals on and off.
My 1988 Coleman used Aux power to run the fridge (I don't know how many amps, though), and I had incandescent lights. Pulled it with 3 different Dodge Caravans. Never had an issue. But these had turn signal relays, not BCM powered.
Furthermore, I'm assuming your A122 was designed this way. So if I'm misunderstanding, you may need to elaborate on exactly what your problem is. In any case, I don't see the fridge-turn signal connection.
2011 Traverse LT, 3.6L, FWD
07-27-2016, 03:24 AM
True - the lights have 2 circuits through the 7 pin, and battery charging and the fridge run off the aux pin. But they all share a common ground (negative) wire. ALL current going to the trailer returns through this single wire. Diagrams recommend 12 Gauge wire which is rated for 20 amps where up to a 5% voltage loss is acceptable (household wiring).
Actual voltage loss is going to depend on the resistance of the parallel path of the metal-to-metal contact through hitch, trailer frame, and TV body/frame. Whether or not the ground wire runs all the way to the engine compartment, alternator, or ties off at the rear of the TV also makes a difference.
I did measure voltages at the camper battery with the fridge running and the tow vehicle plugged in (not hitched up) and running. I saw 12.8V at both idle and 1500 RPM, running lights off. I saw 12.7V running lights on. Camper batteries were at 12.7V prior. But I don't have a lot of confidence in that one test. My digital meter failed completely a day later. But if valid, the measurement implies my camper battery is not being charged while towing. And my camper battery may be being discharged by the fridge. Which matches up with what a lot of seasoned campers have said happens.
I want to repeat the test, measuring at the fridge, and at the camper battery. And while doing the test, I want to disconnect the camper battery and see if there are changes in voltage at the fridge (I have a disconnect wired in).
I also want to check the gauges of the vehicle tow wiring, and see if there is room for improvement to reduce the voltage losses.
I can also reduce the voltage drop caused by the current drawn by the clearance and trailer lights by switching to LEDs.
My goal is to see 13.2 volts or higher at the camper batteries when the TV engine is running, and the fridge is on.
Hope this explains my concerns
Fred W
07-27-2016, 06:55 AM
I hate getting behind vehicles with overly bright rear lights. Some LEDs are so bright and directional they make if uncomfortable to have them in my sight and harder to see anything else at night. Blindingly bright brake lights are a menace on the road.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
07-27-2016, 07:32 AM
I can say that I run with the fridge On, and the headlamps On my TV turned On (it helps to increase the charge to the batteries) and have had no problems keeping the fridge cool. That was true before the LED replacement.
07-27-2016, 07:35 AM
x2...seems like EMS vehicles around here have EXCEEDINGLY bright rear LED lights...especially brake lights...hate getting behind them for sure. Not sure about 'menace' but definitely uncomfortable...
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
07-27-2016, 08:46 AM
Fred W
The computer controlled charging systems used on many new vehicles makes it next to impossible to get an accurate read of the charge voltage to the trailer while the TV is idling. I cannot speak for Hyundai, but I know on later model GM vehicles it gets rather complicated.
On my Silverado, after certain parameters are met (basically cruising down the highway with a fully charged TV battery and no high amp accessories are turned on), the TV output from the generator will be 12.9V. Just enough to sustain the battery and the other required electrical drain.
However, if I simply turn on the headlamps (or turn on Tow/Haul mode), the output voltage of the vehicle goes to 13.9-14.5. That will increase the charge to the trailer. And from an experience of having dead batteries after a long trip without the headlamps On with the fridge running on 12V, and then many long trips with the headlamps On and the fridge on 12V, I learned there is truth in these facts.
07-27-2016, 08:48 AM
Engineer of Crazy Train
On my Roo, the same company makes both incandescent and led versions of the stock light. I swapped out the guts. Kinda wish FR would spend the $5 more for the LEDs in the first place.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
07-27-2016, 09:06 AM
I wouldn't worry about the ground connection. The ground is REALLY through the hitch itself. The ground wire is just an "extra" connection.
07-27-2016, 02:09 PM
Sometimes true, sometimes not. Without knowing the resistance or the voltage drop of the path through the hitch, you can't make an accurate determination. The test would be with the fridge and lights turned on, disconnecting the TV ground wire, and see if there was any difference in voltages at the camper.
I suspect one would find that the path through the hitch is quite variable in resistance, hence the inclusion of the ground wire in the spec. If the ground wire wasn't needed for circuit reliability/performance, it probably wouldn't be there.
Fred W
07-27-2016, 03:58 PM
Fred W
I guess we can agree to disagree. I think the wire is a CYA addition. If there isn't enough contact for a ground, I suspect there isn't enough contact to pull my TT.
