Old 12-26-2015, 12:50 PM   #1
LEDs for Rockwood 128S
Does anybody know what type LED I need for my 2014 Rockwood 128s? The lights that came with this are too bright.
royboy334 is offline   Reply With Quote
Old 01-06-2016, 04:03 PM   #2
My wife feels the same way about the lights on our 2016 A212HW. I'm toying with the idea of fashioning a shade/translucent cover of some kind.
kwf1958 is offline   Reply With Quote
Old 01-06-2016, 05:04 PM   #3
My 2015 A128S lights were way too bright and industrial white. I replaced them with warm white LED RV lights on eBay, which gives the trailer a much warmer and cozier look and feel.
10x Warm White T10 BA15S 1156 LED 48SMD Panel Interior Dome Map RV Trailer Light | eBay
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 01-07-2016, 06:46 AM   #4
MinneweeseMI's Avatar
Take a look...
Search for this: 500mw Interrogation Laser Replacement
It's a little bit of warranty-voiding, but we really like it over the bed. We also hang a small LED light from the vent fan opener knob for when I make coffee in the morning. Keeps the glare out of DW's eyes.
Mark and Dawn
Michigan
2014 a122s
2014 Tacoma Double Cab
Our YouTube Channel
Days Camped 2017: 106
MinneweeseMI is offline   Reply With Quote
Old 01-16-2016, 05:11 PM   #5
World Traveler Member
abdiver's Avatar
This might help you decide. Lumens are for brighness and Kelvin is color of Leds. Both these should be stated on the packaging. There should be a graph on the back showing Kelvin and the low end is around 2700 (soft white) to 6400 for Bright grow lights.
Over the last century, we've been trained to think about light purely in terms of wattages, so it isn't surprising that most people really have no idea of how many lumens they actually need in a bulb. Until you form an idea of how bright is bright enough for your tastes, stick with these figures:
Replacing a 40W bulb: look for at least 450 lumens
Replacing a 60W bulb: look for at least 800 lumens
Replacing a 75W bulb: look for at least 1,100 lumens
Replacing a 100W bulb: look for at least 1,600 lumens
A yellow, low-color-temperature bulb compared with one with a bluish, high color temperature. Ry Crist/CNET Color temperature
After lumens, the next concept you'll want to be sure to understand is color temperature. Measured on the Kelvin scale, color temperature isn't really a measure of heat. Instead, it's a measure of the color that a light source produces, ranging from yellow on the low end of the scale to bluish on the high end, with whitish light in the middle. An easy way to keep track of color temperature is to think of a flame: it starts out yellow and orange, but when it gets really hot, it turns blue.
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
Old 06-06-2016, 06:10 AM   #6
I ended up popping the light cover off and putting a light coat of flat white spray paint on it. Go lightly as you can easily add more light coats of paint later. We're happy with the results. I should have taken before/after photos.
Old 06-06-2016, 07:11 AM   #7
Good Idea
I might try that on the one over the dinette. I wonder if I got a warm color, maybe light orange or yellow...
Mark and Dawn
Michigan
2014 a122s
Our YouTube Channel
Old 06-06-2016, 07:28 AM   #8
The krylon flat white "warmed" up the light considerably.
Old 06-06-2016, 07:40 AM   #9
chuck9997's Avatar
I have a 2014 a122s.. I agree.. most of the time the ceiling LEDs are too bright. But then other times I like the brightness. ...like when I'm cleaning or doing some kind of work inside the camper. So I didn't want to replace them. I bought a small table lamp to put on the microwave cabinet top. I use the cabinet as a nightstand... so a 40 or 60 watt bulb, in the lamp, is just right.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
led, rockwood
