Old 10-30-2012, 04:23 PM   #1
lesson learn
Just finished my third trip second to TRF dry primitive camping and learn a few things. The furnace will run about 12 hours before running down the battery. Need to remember to recharge during the day. Second a small camp heater will really warm up the camper fast, even with the ceiling vent cracked open and the camper will hold its heat for a couple of hours, at least if the temp is in the upper 30ís. Even at low speed 5-10 mph will cause the door under the microwave come open on rough roads. Need to look into a method to keep closed off road. A frames get lots of attention which is a nice way to break the ice with neighboring campers. Leveling blocks are not the easiest way to level a camper need to invest in a better solution. And the door of the camper is not quite big enough for a fully armoured knight to go through, pretty sure that is not an issue for most campers. On same note make sure to remove WarHammer before entering the camper.
RenFaire Camper is offline   Reply With Quote
Old 10-30-2012, 04:30 PM   #2
2012 Flagstaff T-12DD
2004 Chevy Suburban
2000 GMC Sierra Z-71
loganmartin is offline   Reply With Quote
Old 10-30-2012, 04:43 PM   #3
TURBS's Avatar
Originally Posted by RenFaire Camper
Just finished my third trip second to TRF dry primitive camping and learn a few things. The furnace will run about 12 hours before running down the battery. Need to remember to recharge during the day. Second a small camp heater will really warm up the camper fast, even with the ceiling vent cracked open and the camper will hold its heat for a couple of hours, at least if the temp is in the upper 30’s. Even at low speed 5-10 mph will cause the door under the microwave come open on rough roads. Need to look into a method to keep closed off road. A frames get lots of attention which is a nice way to break the ice with neighboring campers. Leveling blocks are not the easiest way to level a camper need to invest in a better solution. And the door of the camper is not quite big enough for a fully armoured knight to go through, pretty sure that is not an issue for most campers. On same note make sure to remove WarHammer before entering the camper.
Have you tried goin in sideways?
Old 10-30-2012, 04:45 PM   #4
extremebike's Avatar
Smile levelling pop up
Hi!
I used to use a 2x10 about 2 feet long with a 2x6 under one end then have my wife watch the side to side level unit it was good then have her kick in a chock while still hooked up.
With the 2x10 on a tilt you have some play, block flat on the ground never get you level side to side.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 10-30-2012, 04:46 PM   #5
You need this.....love mine BAL Light Trailer Tire Leveler - BAL 28050 - Chocks & Levelers - Camping World
Trevor43 is offline   Reply With Quote
Old 10-30-2012, 05:40 PM   #6
Rockwood Premier A126
gregory's Avatar
We like using these:
Tri-Lynx 00015 Lynx Leveler for RV Leveling Block with Nylon Storage Case,(Pack of 10) : Amazon.com : Automotive
btw, Hilarious notes about armor/door size and War Hammer!
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 10-30-2012, 09:24 PM   #7
Originally Posted by Trevor43 View Post
Thanks that looks like what I need going to order one before my next trip over Thanksgiving.
Old 10-30-2012, 09:26 PM   #8
Renfaire camping is always interesting should see the wife trying to get her hoop skirt through the door.
Old 10-30-2012, 10:00 PM   #9
DGrissom's Avatar
Just finished my third trip second to TRF dry primitive camping and learn a few things. .... Even at low speed 5-10 mph will cause the door under the microwave come open on rough roads. Need to look into a method to keep closed off road. ....
We have had good luck with a small (7-8") bungee cord stretched between the upper and lower metal vents over the microwave door. Before that, we would sometimes find the turntable plate on the floor after towing.
David and Jo Ann G. (& Kenzie the Sheltie)
Prattville, Alabama
2018 Flagstaff E-Pro 19FD "Phoebe" 18 Nights!
2012 Rockwood A128S "Rocko" 200+ Nights!
Nights Camped 2012 - 2017 = 226
Nights Camped 2018 = 0 as of today)
DGrissom is offline   Reply With Quote
Old 10-31-2012, 11:01 AM   #10
Yukon Don's Avatar
Originally Posted by RenFaire Camper View Post
...And the door of the camper is not quite big enough for a fully armoured knight to go through, pretty sure that is not an issue for most campers. On same note make sure to remove WarHammer before entering the camper.
Good grief! Are the mosquitos that bad where you camp?!?!
2009 Jeep Wrangler Unlimited
2012 Flagstaff T10RD
Yukon Don is offline   Reply With Quote
