Set your level on the floor where it can be seen from the door, and get the left to right square. I use an anderson leveler to make this fast and easy, but you can use a BAL leveler, or blocks, or whatever you feel most comfortable with. then use the tongue to set the front to back.
Once level, crank your stabilizers down till they touch, and give em a little more, maybe half a turn, depending on the surface.
I've found everything shifts a bit after its been unloaded and camp is set up, but nothing so far out that a few small adjustments of the stabs doesnt fix.
2016 212HW led valiantly into the beyond by a 2010 Track Edition Ford Ranger 4x4.
Nights camped 2016: 14
Nights camped 2017: 11 (so far)
