Old 07-15-2017, 02:15 PM   #1
Lift motor trouble
Just wondering if anyone else has the lift-assist motor installed on their unit and if they have ever had trouble with it?
jncadventures is offline   Reply With Quote
Old 07-15-2017, 02:43 PM   #2
Randy Hoffman's Avatar
Search roof actuator in the forum, lots of info on this.
Randy Hoffman is offline   Reply With Quote
Old 07-15-2017, 02:45 PM   #3
I have one, no trouble yet. Knock on wood. You having an issue?
There is some huge thread about it but ive not read it
16' T21DMHW - Gone solar - 3/4ton truck to pull it with
glarior is offline   Reply With Quote
Old 07-15-2017, 03:03 PM   #4
motor recently went out -- wondered if it was a common issue or just a fluke thing ... have only owned the unit about 10 months when it went out
Old 07-15-2017, 03:23 PM   #5
I couldn't answer that. Ive had mine for 1.5 years and its been used a lot including beach trips on north padre island. The beach ruined my generator but the lift motor still working. Maybe that thread will give you better answers? Good luck!
Old 07-15-2017, 05:12 PM   #6
Smile
Thanks. From what I can tell, it was just a bad motor and there are remedies to it. Wish I would have joined this site sooner !
Old 07-16-2017, 08:53 AM   #7
Consensus is that it is not uncommon for them to fail. My motor failed after 2 trips. Some think it is a water infusion issue.
cpttimerstraint is offline   Reply With Quote
Old 07-16-2017, 09:27 AM   #8
Jacink's Avatar
Call Rieco Titan products it has a lifetime warranty, as long as you own the Camper.
They replaced mine for free just had to send the old one back.
https://www.riecotitan.com/
Jacink is offline   Reply With Quote
Old 07-16-2017, 01:23 PM   #9
awesome to know, thanks
Old 07-16-2017, 01:24 PM   #10
thanks for the info -- I wonder what water infusion issue is ? Like does it fail because of being rained on, etc??
Old 07-16-2017, 05:35 PM   #11
I have it. Never had a problem, and I mounted a solar panel. I pulled the specs and am still under the max rating.
carlsbad is offline   Reply With Quote
Old 07-16-2017, 08:34 PM   #12
Bought my unit in Jan, 2017. Raised and lowered no more than 4 times and the units has failed.
Fortunately I was aware of the ability of removing the top connect and manually using the unit.
dhubbca is offline   Reply With Quote
Old 07-16-2017, 10:40 PM   #13
Thumbs up
wow, everyone has been so helpful - thanks to all -- my unit will be repaired this week and it'll be nice to go out again -- will remember about disconnecting it and raising manually - didn't know you could do that -- I could have been going out camping instead of waiting on the dealer to fix the problem!
Old 07-17-2017, 01:16 AM   #14
Auto correct gave me infusion, not intrusion. Water can get between the shaft and the housing.
lift
