Old 05-15-2015, 07:59 AM   #11
dieselguy's Avatar
"This tells me what I had already had guessed - a dual axle installation is much harder on tires than a single axle."
I don't think "harder" is speculating correctly here. Although I pull in the 12.5K plus category ... I've never worn out any tandem axle tires in over 20 years of RVing. I seldom go over 5 years on tires. Not because of wear, but because of carcas lifespan.
dieselguy is offline   Reply With Quote
Old 05-16-2015, 08:15 PM   #12
Are there plenty of tandem axle RVs that don't have tire failures? Sure. But there are still a disturbing number of catastrophic tire failures being reported on various forums. And I stand by my conclusion that the squirming and side-ways rolling of the tire that is more prevalent in tandem (dual) axle configurations is a common failure mode for trailer tires. Otherwise, the manufacturer wouldn't derate his tires by 11% for a dual axle installation.
The obvious other conclusion is that running tires at less than 90% of load capacity is a good thing, apparently significantly decreasing risk of failure.
Fred W
2014 Rockwood A122
2008 Hyundai Entourage (minivan)
Old 05-16-2015, 08:31 PM   #13
Lvn2tvl's Avatar
Well I can say last year when servicing bearings on my 06 5r I accidentally spotted an issue in between the tread on one of these very tires. Looking closer I saw hairline cracks all the way around the tire and between all tread gaps. There was no sign of a problem when I looked from the side of the tires. Worse yet I looked at the others and all 4 had cracks. Went to DISCOUNT TIRE and replaced them all. Scary with 6000+ lbs riding on them.
Lvn2tvl is offline   Reply With Quote
Old 05-16-2015, 08:43 PM   #14
vinmaker's Avatar
Originally Posted by steve999 View Post
These tires are the only D rated tires (65 psi max) I've ever seen for a 13" wheel. I just put them on my trailer. Even if you think these tires are Chinese cheapies, I don't know of any alternative.
I'd like to here how these tires have worked for everybody. Post up how long you've had them, how many miles if known, and if you've had any issues.
Just fyi for those that don't know, blowouts tear up the floor of your trailer and do a lot of damage, so good tires are really important.
I agree. You do not usually see D rated tires in a 13" rim. Heck. I would have a hard time finding D rated for a 14".
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-16-2015, 08:47 PM   #15
dannyabear's Avatar
MSLA I think you read the chart wrong; tires are de-rated when used in dual wheel applications (like 1 ton trucks) not dual axles.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 05-16-2015, 08:58 PM   #16
Done with this
We had Load Stars on our old pop up. Never had a problem or complaint. Bought it with them and sold it with the same tires 6 years later.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 05-16-2015, 09:19 PM   #17
X2
Old 05-17-2015, 05:45 AM   #18
Thanks....but wasn't me that said that. I never knew they were de-rated for any reason so I plead ignorance.
David
Tow Vehicle: 2012 Durango 3.6 Pentastar Engine
Total nights camping 2014-(10)
Total Nights Camping 2015-(9)
Total Nights Camping 2016-(5)
Total Nights Camping 2017-(4)
Total Nights Camping 2018-(7)
mlsa3 is offline   Reply With Quote
Old 05-17-2015, 08:40 AM   #19
It was me. Printed on the sidewall (among other warnings and ply makeup) of my 2014 Rockwood A122 OEM tires:
Westlake
ST185/80R13 Load Range D
max load single axle 1710 lbs at 65 PSI
max load dual axle 1520 lbs at 65 PSI
I was surprised when I read all the fine print on the sidewall. I was also surprised that I could not find another brand of same size trailer tire in load range D on-line at any of the popular sites.
Fred W
2014 Rockwood A122 A-frame
Old 05-17-2015, 02:35 PM   #20
Who would put trailer tires sized for a pop up on a dually truck?
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
tire, tires
