Old 09-28-2015, 07:22 AM   #91
Wolverine 1945's Avatar
Originally Posted by PhoneDude 8289 View Post
X2. The first time I pulled it last fall I had to use a 1-1/6 socket, extension and breaker bar. Now it's teflon and snug it up, comes off real easy now.
Right On !!!
As I said it is not a lug nut,,, or a mower blade !!!
If it does not leak,,, it is plenty tight enough !!!
Wolverine 1945 is offline   Reply With Quote
Old 09-28-2015, 09:35 AM   #92
deartruc's Avatar
Only used our new 2015 once last fall for a 4 day trip. Dealer winterized it for us when we got back (it was in for warrantee work). The side of the camper was soaked in calcium.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 06-13-2016, 11:44 PM   #93
JArry's Avatar
Hate to revive an old thread, but...
This seems like the logical place to post. I am wondering if it is normal or necessary for the anode rod nut to be completely tightened flush with the outer edge of the drain hole. Mine shows about 1/4-inch of exposed threads and is very tight to the point that I think additional tightening would risk stripping the threads. Last time I tightened it to a seemingly reasonable amount, water leaked around the rod. It is thread-taped. I mentioned the leak to the dealer; I think they tinkered with it, and they claim the leak was fixed. However, it doesn't look like they did anything since my earlier attempts, and I have not filled and pressurized the tank since then.
If it makes any difference, both the rod nut and the drain hole threads are quite rusty and have been since "new" (2016 Flagstaff 12RBST obtained this year). The rod itself is fully intact and the heater has been used only to fill and test.
Thanks!
JArry is offline   Reply With Quote
Old 06-14-2016, 01:28 AM   #94
2007 WildCat 32QBBS
05CrewDually's Avatar
The anode rod is National Pipe Thread and is tapered. So when you turn it, it is tightening in the bung like a wedge. You should have some threads exposed even after tightening. Use three full wraps of Teflon tape wrapping it counter clockwise. Tighten it enough so there's no leak. If you see a drip, go a little more.
05CrewDually is offline   Reply With Quote
Old 06-14-2016, 06:32 AM   #95
JArry's Avatar
Thank you for the clarification!
Old 06-14-2016, 04:37 PM   #96
Mikegjax's Avatar
Installation instructions for the rod usually state "no more than 1 1/4 raps of Teflon tape. Idea is you must cut through enough tape to make good metal to metal contact. I usually check continuity with an omh meter after installation.
2014 Solera 24R
USN Retired
Mikegjax is online now   Reply With Quote
Old 06-15-2016, 06:39 AM   #97
Maybe that is why my Anode Rod is in such good shape,,, either to much Teflon tape ??? Or filtered soft water ???
Question for one of our plumbers,,,
Does it matter which way we rap out Teflon tape,,,
Clockwise or Counterclockwise ???
I vote NO !!!
Old 06-15-2016, 07:08 AM   #98
bubbles's Avatar
No. however, typically with all plumbing items where used it is installed clockwise when viewing threaded end (right hand threads). This assures the tape will not try to bunch up or unwind when item is screwed in.
Old 06-15-2016, 07:32 AM   #99
I have used many many roles of Teflon tape,,, and have never had one bunch up or unwind,,, maybe because I apply the tape very tightly ???
Thanks for your reply !!!
Old 06-15-2016, 07:33 AM   #100
nomad297's Avatar
I vote NO !!!
Plumber here. You start the tape at the end of the thread that goes into the fitting and follow the direction of the thread as you wrap up towards the larger diameter of the NPT threads. It is hard to describe it as clockwise or counterclockwise because it all depends on which way you are looking at the threads.
Bruce
nomad297 is online now   Reply With Quote
anode
