Old 06-15-2016, 12:19 PM   #111
Restcure's Avatar
To each his own, of course. Our anode rod has never been hard to remove in the fall and it degrades so little during the season that I have no worries about whether it needs replacement mid-year.
And since (a) we don't drink the hot water (or any of the tank water, for that matter) and (b) the sediment in the tank tends to stay at the bottom, I see no reason to change my procedures.
But, I repeat... to each his (or her) own!
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 06-15-2016, 02:48 PM   #112
Mr. Dan's Avatar
Originally Posted by JD and Beastlet View Post
A little late to this party but I'll add my 2 cents...
I see no reason to empty the water heater after every trip. The anode rod is removed in the fall during winterizing to flush out the tank. It's inspected at that time and replaced if necessary. We had our last trailer for eight years and replaced it once.
I put Teflon tape on the threads and thread it in manually to start. As mentioned, the weight of the the rod tends to angle it down so I'm mindful of that when reinstalling. It gets snugged in firmly but is not cranked super tight. I've never had a problem removing it.
This is also my process/thinking. I don't ever remember drinking water out of my water heater. Grandmother England said a person should NEVER drink water from a house WH... said the heater had fiberglass insulation in it. I asked "IN it?" (crickets)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 06-15-2016, 05:28 PM   #113
Canadian Member
itat's Avatar
We do drink the water that comes out of the WH although it gets boiled in the kettle for tea and boiled for potatoes. If you use it for showering you likely ingest a bit in the shower.
I worked for 25 years in the municipal water supply industry so I guess I'm more cautious than most.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 06-16-2016, 03:17 AM   #114
Witch Doctor's Avatar
I just put a couple of wraps around the thread and it will bunch up at the end a little. I check mine once a year and in 4 years there has been very little deterioration. It lets me confirm it's working. Then blow out the crud in the tank. Reinstall and ready to go. I don't think I have ever checked my W/H at home. If you read about the two different materials that they are made for and buy the right one they should last a pretty long time. The hard part is not breaking it loose to me, it's reinstalling it so I don't cross thread it. I see no use in draining the tank after each use. I just let the water drain out through the faucet and let it refill with new clean water. I keep an extra one and an electric element in my tool box. I'm more concern with the electrical element then the rod....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 06-16-2016, 05:52 AM   #115
Wolverine 1945's Avatar
Originally Posted by 05CrewDually View Post
Yes it matters as others explained.
It hasn't bunched up on you because you're probably wrapping it correctly, counterclockwise.
Any thing is possible !!! I am right handed !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-16-2016, 05:58 AM   #116
I would drain my home WH every year or so if it were not in the basement !!!
Old 06-16-2016, 04:29 PM   #117
World Traveler Member
abdiver's Avatar
Originally Posted by fast murray View Post
wd-40 and an impact gun. I put Teflon on mine and use a breaker bar. You don't have to actually get it crazy tight. I take mine out to drain the tank after every trip, new Teflon and loosly screw it in until I'm ready to use it.
My unit is fairly new about 1 1/2 years and I was at my anode that has never been removed, but I noticed it is very rusty and it looks like they have Teflon on the threads so I should be able to get it out with a breaker bar. Is everyone Else's fully rusted also?
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
Old 06-16-2016, 08:34 PM   #118
Mikegjax's Avatar
They all rust on the outside. Yes you should be able to get it out using a 1 1/6 socket and bresker bar. The ones I have replaced call for 7 foot pounds of torgue when installing. No need to over tighten.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-17-2016, 12:02 AM   #119
It should be 1 1/16th inch socket not 1 1/6th.
2012 Rockwood a124
mzak is offline   Reply With Quote
Old 06-17-2016, 12:18 AM   #120
dea49's Avatar
Originally Posted by Mikegjax View Post
Installation instructions for the rod usually state "no more than 1 1/4 raps of Teflon tape. Idea is you must cut through enough tape to make good metal to metal contact. I usually check continuity with an omh meter after installation.
I have not been using Teflon tape for many years. I use pipe dope with Teflon. Never had a leak, wherever I used it.
dea49 is offline   Reply With Quote
anode
