09-22-2015, 01:27 PM
#21
Alleged curmudgeon
Originally Posted by AquaMan
I've always used a basin wrench to take my anode rod out and to just snug it up when installing. I also don't replace it as long as there is sacrificial material left. We are on season 4 on this rod.
x2 on the both the "just snug it up" and 4th season comments
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
09-22-2015, 03:42 PM
#22
Anode Rod Removal
Originally Posted by kdot
Nut Cracker or Liquid Wrench. The anode probably takes a 1-1/16 socket, on a short extension. All the talk about breaker bars sounds scary. The anode should NEVER be turned in that tight. Like others have said, just snug it up with the Teflon tape. Incidentally, I've found that anodes need to be replaced about once a season. Incidentally X2, never remove an anode without making sure that there's no pressure in the line; always pull the relief valve first! Beats getting wet.
Kdot
Great advice! I forgot to open the releif valve the last time I drained my water heater to winterize and I received a great reminder! Water and the crud sediment all over my shirt and jeans! Had to laugh at myself and so did my wife!
09-22-2015, 03:55 PM
#23
...Also, be aware that the socket usually requires a 1-1/2 inch drive, so you'll need that size wrench and a short extension. They'll cost you a little bit of money but those three pieces probably ought to be in every camper's tool box!
Kdot
And what are you going to do with a 1-1/2" drive? Never seen one quite that large.
09-22-2015, 04:02 PM
#24
PB Blaster works great. Once it is out and repalced, remove it annually to prevent it from seizing up again.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-22-2015, 04:16 PM
#25
I only own 3/8 wrenches. I purchased my 1 1/16 socket (1/2 drive) at Lowes along with a short extension - 1/2 to 3/8 adapter.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
09-22-2015, 04:36 PM
#26
Originally Posted by clr
I have always used a set of shower valve sockets. They come is a large clip with a bar that goes thru the other end of the sockets and there is a 1 and 1/2 inch socket for the anode rod, also they are relatively light to carry with you.
I'm afraid your 1-1/2" socket will not loosen the anode as it is 1-1/16".
09-22-2015, 04:40 PM
#27
Loosening the anode rod
Yes, you can use adaptors and a 1-1/8 socket, but it will be loose and run the risk of stripping the corners on the anode. And why buy adaptors when, for a few dollars more, you can get the 1-1/2 inch drive wrench and do it right. Incidentally, the 1/2 inch drive wrench and appropriate socket also fits trailer lug nuts!
kdot
2019 Flagstaff E-Pro 19FBS
2017 Honda Pilot
09-22-2015, 04:47 PM
#28
Many years ago I bought a folding tire wrench at Walmart in USA. It opens and forms a 4 point cross with 4 sizes of sockets. One size (forget which one) works just fine to turn out the anode rod. Handy tool to have for TV or Trailer wheels. I keep it stored in the cubby that has the hot water tank, water filter, and pump so I never have to hunt for it.
2014 Flagstaff 27RLWS
Planned 10 year cottage (no Truck)
Prairie Sky Rv, Coaldale, Alberta
09-22-2015, 05:00 PM
#29
Throughout my lifetime this FR trailer has the first electric WH I've ever had. We will rarely use AC power as we camp at National Forest and State campgrounds without hookups most of the time. Do you think the anode will still need annual replacement?
09-22-2015, 05:39 PM
#30
Heating method has nothing to do with anode life. Anode life depends on the water.
09-22-2015, 05:43 PM
#31
You know 4/3 of all people do not understand fraction.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
09-22-2015, 05:55 PM
#32
I think you meant to say 3/4 of all ...!
#33
See. Another vote for the metric system!
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
09-22-2015, 06:14 PM
#34
2008 F350 CCSB V10
2016 Sabre 36QBOK
Not my vote.
09-22-2015, 06:17 PM
#35
No I did not. Think about it. : :
Steve and Adele
2017 RB-195
09-22-2015, 06:50 PM
#36
Not my vote.
Someday you will join the rest of the world.
Even your military has joined the dark side.
2008 F350 CCSB V10
2016 Sabre 36QBOK
09-22-2015, 07:39 PM
#37
Ok - then 1.3333333333.
09-22-2015, 07:42 PM
#38
2008 F350 CCSB V10
2016 Sabre 36QBOK
Yeah -I know. But the old U.S. way has served me and my generation well, so I'll stick with it.
09-22-2015, 07:48 PM
#39
Randy and Diane, hey that's a neat idea! I have one of those cross-shaped tire irons; I bought it some years back because it gives me greater leverage when trying to loosen tight lug nuts. I never thought to check and see if one of the nut sizes on it also fits the water heater anode. If it does, that would eliminate having to have the 1/2 inch drive wrench, extension, and socket on board. I'm definitely going to check that out. Thanks for the info!
Kdot
2017 Honda Pilot
09-22-2015, 08:13 PM
#40
[QUOTE=kdot;991198]Randy and Diane, hey that's a neat idea! I have one of those cross-shaped tire irons; I bought it some years back because it gives me greater leverage when trying to loosen tight lug nuts. I never thought to check and see if one of the nut sizes on it also fits the water heater anode. If it does, that would eliminate having to have the 1/2 inch drive wrench, extension, and socket on board. I'm definitely going to check that out. Thanks for the info! END QUOTE
I wondered if that lug wrench might work, will check on that tomorrow.
Thanks everyone
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
