Old 12-09-2015, 03:19 PM   #1
ccamper's Avatar
Love my a192HW
I am very happy to find this forum. I have read many of the threads, and found a lot of useful information, tips, and tricks. So, thank you to all who have posted. Here are a couple of pics of my new(ish), purchased back in April, A-frame.
ID:	95854   Click image for larger version
ID:	95855   Click image for larger version
ccamper is offline   Reply With Quote
Old 12-09-2015, 03:54 PM   #2
chaviva7's Avatar
We had the 194 HW. We loved it but went bigger with the 2016 214HW. Happy camping days to you.
chaviva7 is offline   Reply With Quote
Old 12-09-2015, 04:51 PM   #3
DanM-AZ's Avatar
Well that proves that you can do solar on the front slope even if you have the bubble windows! Can you give some details on your solar installation?
Thanks!
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 12-10-2015, 07:25 AM   #4
mudman2's Avatar
That looks like 3m tape on the bubble Windows. Did it come from the factory like that?
2019 microlite 25bds
2015 tundra
mudman2 is online now   Reply With Quote
Old 12-10-2015, 07:49 AM   #5
ccamper's Avatar
DanM, I mounted the panel there because I like concealed wires. The roof being a fiberglass/rigid insulation/metal sandwich, can't run wires within the ceiling. By mounting it here, I drilled through the roof, and the wires run along the inside if the roof hinge then down the front wall into the space below the dinette seat. I mounted the charge controller next to the inverter. Ran from inverter through existing hole in floor to battery. Was going to just tap battery at inverter, but this one doesnt have 12v lugs like older models. All circuit boards now. The panel itself is mounted on Z brackets. This gives about an inch of airspace beneath the panel. The brackets are mounted with stainless steel screws. I thought I would have to through bolt, but the screws bit and grabbed very tight. I sealed bracket screws and wire penetrations with black solar seal caulk. A roofing caulk. Its a renogy solar panel kit , (100 watt panel, 30amp charge controller, mounting hardware, and cables) bought off amazon for about $185.00. I camped in S. Dakota for a week using battery for lights, radio, propane for fridge and cooking. Battery never drained low fkr the whole trip. I have more install pics, but on my old phone. I will have to find them and post.
Old 12-10-2015, 07:53 AM   #6
ccamper's Avatar
Mudman2, the bubble windows are the way they came from the factory. Not sure is 3m tape. I believe they are and then caulked around the perimeter.
Old 12-10-2015, 09:40 AM   #7
ccamper's Avatar
Here is a straight on view of the solar panel. Also some pics of winter storage.
ID:	95894   Click image for larger version
ID:	95897   Click image for larger version
ID:	95898   Click image for larger version
Old 12-10-2015, 12:52 PM   #8
DanM-AZ's Avatar
Thanks ccamper,
That looks and sounds like a pretty clean installation. I couldn't bring myself to penetrate the roof panel.
If the bubble window installation is factory stock, there may come a day when you need to apply the 3M Extreme Sealing tape. That will be complicated by the solar panel. You may need to remove the panel to apply the tape, then reinstall it.
Here is what a 3M tape installation looks like:
Dan
Old 12-10-2015, 01:07 PM   #9
ccamper's Avatar
Thank you, I did think about it during install. Lol. I remember telling myself that these windows will be a problem later on. I'll cross that path when I get there. I'm sure within the next year or two. But thank you again.
Are those factory rivots or screws in yhe corners under the tape? Mine doesn't have those.
Old 12-10-2015, 05:03 PM   #10
DanM-AZ's Avatar
Yeah those are factory screws. Mine is an older model, 2012 model year, built in 2011. That's the rear window. Mine doesn't have front bubble windows. Build details may have changed since mine was built.
Dan
