The temperature here was predicted to drop below freezing, so I decided to drain my A122S. The low point drain valves, under the driver's side dinette seat just turn endlessly in both directions. No water under the trailer. I thought maybe the valve handle needed to be lined up with the water line to drain. Nothing. I tried everything I could think of and no water drained out.
Do the valves pull out, push in, do the hokey-pokey? Anyone with an A-frame know?
Kent
