Old 11-11-2016, 08:51 AM   #1
kdot's Avatar
Lubrication?
I'm wondering what folks are using to lubricate the gasket that is supposed to seal the place where the top meets the bottom of the roof when the camper is folded down. I've also noted that there is a slight sag in the rear roof and when the camper is folded down there is a little space in the middle, where the front roof meets the rear and water can get inside. Has anyone else had this happen, and have you done anything about it?
Kdot
2019 Flagstaff E-Pro 19FBS
2017 Honda Pilot
kdot is offline   Reply With Quote
Old 11-11-2016, 09:08 AM   #2
On my popup I use spray silicone on the bulb gasket, in fact on all rubber gaskets and door seals on everything, cars included. Cannot comment on the space, sounds like an adjustment is needed.
SidecarFlip is offline   Reply With Quote
Old 11-11-2016, 11:23 AM   #3
Read the warped roof panel post below. There are pics of a somewhat common issue. Mine required roof replacement.
2016 212HW led valiantly into the beyond by a 2010 Track Edition Ford Ranger 4x4.
Nights camped 2016: 14
Nights camped 2017: 11 (so far)
Luv70sFords is offline   Reply With Quote
Old 11-11-2016, 11:56 AM   #4
X2
2012 Rockwood a124
mzak is offline   Reply With Quote
Old 11-11-2016, 12:23 PM   #5
kdot's Avatar
Lubrication
Love70sFords: I couldn't find any link or pictures for what you're describing.
Kdot
2017 Honda Pilot
Old 11-11-2016, 12:58 PM   #6
http://www.forestriverforums.com/for...el-107939.html
Old 11-13-2016, 08:08 PM   #7
Use nothing....only replace when necessary . ..may be doing mine next year...build date is oct 2010.
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 11-19-2016, 11:08 PM   #8
This is what the rep told me to use, 303 (30324) Rubber Seal Protectant and Conditioner for Weather Seals, you can find it on Amazon. Silicone may make it look pretty but it actually does more damage over time.
sundancer330 is offline   Reply With Quote
Old 11-20-2016, 02:00 AM   #9
Depends on the silicone. Water based would be OK but petroleum based not so much. GM actually recommends silicone for weatherstrips on their vehicles according to the owner's manual.
Some people also recommend dielectric grease for seals.
2012 Rockwood a124
Old 11-20-2016, 08:52 AM   #10
Dsfast's Avatar
Yes GM recommends silicone on its weather stripping but it's there silicone emoltion that you buy from them. If you use spray silicone it can get into your oxygen senders and coat them. Can be a expensive mistake. I use the silicone emoltion on the weatherstripping on mu 128s every spring and fall
Dsfast is offline   Reply With Quote
Old 11-20-2016, 11:11 AM   #11
Did you mean oxygen "sensors"?
Bottom line is that silicone can be used but it is important to use the right type. GM's would work fine but not necessarily the only one. If you google the use of silicone on seals and weatherstrips there is much information on this topic.
2012 Rockwood a124
Old 11-20-2016, 07:26 PM   #12
Dsfast's Avatar
Yes I meant sensors. But as per countless service bulletins from both gm,ford and Chrysler in my shop we don't use silicone. But it is your choice for shure
Old 11-21-2016, 10:32 PM   #13
The dealer I bought my A122 at installed additional piece of rubberized weather seal on the upper panels lip. If you look at other manufacturers they have it already.
Banjo64 is offline   Reply With Quote
Old 11-22-2016, 08:24 AM   #14
kdot's Avatar
Lubrication
Lots of good suggestions to my original question and I appreciate them. The 303 sounds good, and the suggestion about adding a piece of weather strip to the upper roof lip sounds workable also. Many thanks!
Kdot
2017 Honda Pilot
cat
