Old 06-16-2013, 11:42 AM   #21
ko777's Avatar
Originally Posted by ko777 View Post
I just updated my thread post #353 on how I installed my MM, A128S Converted from ALINER Ranger
Check this out, I just did my MM setup last weekend. Putting the mesh away with this setup is easy and it does not interfere when the A-Frame gets folded.
If you are planning to do the one panel door setup, consider that when you step out, it will be a little tight especially for a tall person. You will have to bow before going through the mesh. Going in is easy and it should be the same feel as the two panel door mesh setup. For 5'9" and shorter, I recommend the one panel door mesh setup and it is so much easier to install too.
Good Luck!
ko777 is offline   Reply With Quote
Old 06-16-2013, 11:43 AM   #22
handbuilder's Avatar
Hi Khaapala! I just used the Magic Mesh panels and the velcro that it came with. I measured and pinned each panel to equate to the doorframe width, folding it over on itself (I was afraid to actually trust my measurements and cut it) AND I didnt want to worry about having to finsih an edge. I make no claim to being a seamstress, so after pinning the excess panel width on top of itself, it was just sewn down lengthwise to secure the folds. The length was cut to the height of the entry.
I love the having it! Most of the time the door is open and the screen is up....even when we go to sleep...our EZ Up canopy with its sidewalls blocks the front of the camper. I use my trailer alot at dog shows & always blasting in and out of the trailer. I like that it is quiet hands free entry and it self closes. I can push my arm through to get a fresh cup of coffee without having to walk in or disturb DH if he is napping with a door opening/closing. It works hard for me on my times out & I like that I dont worry about ripping it off the frame. The Magic Mesh is an easy project - If I can do it, you will have no prob! Love to see pics of yours once its done!
Do you have the pull out sofa bed model or the newer flip up bed? What do you use your deck for? I'm in WA too but we like to go rockhounding in OR and ID...Have you done any mods on your TH? I am always on the lookout for improving the trailer's ease of use! Not many of us on here with the TH model. Do tell, please!!
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 06-23-2013, 08:47 AM   #23
Bojo's Avatar
Thank you for posting! We have been considering this mod for some time. The photos and ideas really help. Looks like this is the summer. Happy camping all!
Bojo is offline   Reply With Quote
Old 06-23-2013, 05:38 PM   #24
I guess I am your 'go to' guy for goof-it-ups...... I don't yet have the MM up but I did put the velcro tape on the back side of the door frame. With great pride I put the tape on while the door was open and of course placed a piece of velcro tape exactly where the upper door latch closes. Now to remove a small section of that piece of tape.
Moral: I recommend installing tape while the door is closed.
neil.ervin is offline   Reply With Quote
Old 06-23-2013, 07:33 PM   #25
Mostly Harmless
thehamguy1's Avatar
I'm also working on getting a Magic Mesh screen installed. So far I've laid it out and folded it to the width it needs to be cut and sewn to. Once the dimensions were right I stapled the screen edge to its future position (when sewn). After finding someone with a sewing machine to fasten it permanently, I'll cut off the excess and take out the staples.
Laid out on floor and taped to desired width (20 - 5/8" from outside to outside, folded over material to be cut off when sewing's done)
Measurements shown.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 06-24-2013, 01:29 AM   #26
Looks good Lee! I did something similar! Never thought to use staples, the pins I used were deadly! haha
Old 06-24-2013, 06:00 AM   #27
Originally Posted by handbuilder View Post
Here is what it looks like when the Magic Mesh screen door is not in place. Velcro strips not pretty to look at, but when we are using the trailer, the screen is in place and we dont have to look at them haha
There are 3 velcros on each side and 4 at the top
Might try to mount the MM to a board and use 2 z pcs of channel mounted to the wall and just slip the board in the channel to or something similar to replace the Velcro?
Old 06-30-2013, 09:50 AM   #28
Attachment 33875
Attachment 33876
Measurements shown.
What are your plans for the height? Measure and hem the bottom? Do you know that measurement off-hand? Would the bottom hem benefit from a bit of weight?
2011 A-122
rawlus is offline   Reply With Quote
Old 06-30-2013, 04:20 PM   #29
Mostly Harmless
thehamguy1's Avatar
On my A128, the measurement from the threshold to the top of the pad over the door is 72". I plan to fold the screen top over so the black edging at the top of the screen is at 72" and sew it there. Then I'll cut off the excess on both sides and the top. I'll remove the pad over the door, install the screen, and reinstall the pad. That should do it; so far none of those who've already installed their MM have said they need weight added at the hem, so we'll see.
I haven't found anyone with a sewing machine yet so the project is on hold. Meanwhile I need to remove the remnants of my earlier screen. That may take some doing; I epoxied the magnets to the door frame in V. 2.0, and they'll have to come off. That version still works OK, but it's not as elegant a solution as V. 3.0, using the MM.
2011 Rockwood A128
60W solar system
Old 06-30-2013, 05:16 PM   #30
Rockwood Premier A126
gregory's Avatar
Hamguy, in your project, please tell us how you take the header pad off the wall that is over the door. Can you just use a screwdriver to pry off the buttons revealing screws? I'm curious to see what our door looks like w/o the padding and if it is feasible to discard it all together.
Also, if the MM is installed "permanently" under the padding, do you plant to roll it up when not in use... or just let it hang after fold down and during travel?
For Gary and I, this project has been on the back burner a while now, so I've been reading everyone's posts for ideas. Here is what I am considering doing:
I have concerns about my ability of cutting and sewing the length of both panels in a straight neat manner. So for width, I think I'll fold over and sew the MM width to fit the door, similar to the way handbuilder did.
To hang the MM we picked up a 21" sash curtain rod today.
I was thinking of attaching the curtain rod into the wall over the door. I'll sew some black binding along the top to form a "pocket" the rod will slide into. I'll have to trust that I can sew that short of a distance neatly...we'll see how well that works out...
The idea is that we'll have the option of taking it down while in route or if the screen is not needed leaving small brackets instead of Velcro along the top.
I also picked up white Velcro to replace the black that came with the MM kit. I think the white will be more discrete when the MM curtain is not in use.
If the curtain rod idea doesn't work out, we may look into removing the door header padding and attaching it under there like thehamguy...
I'll post pics when the project is completed... fingers crossed, hopefully later tomorrow.
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
