making modifications!
Looking to see if anyone else has some input. I've got a new 212HW, and want to add a battery monitor and some USB ports. I plan on tapping into the power going to the radio. The USB ports dont pull a lot of amps, and making a plate for it all to mount under the radio will be easy. I plan on an on off switch for the USB to reduce parasitic draw when not in use, as well as a momentary switch for the battery meter.
Also, has anyone wanted to swing the fridge door the other way? I started to swap it today, but the hinges are not reversible. Can I order them from dometic?
I did manage to make a grey water tank out of a washing machine hose and some fittings from the hardware store. Removed the valve from a walmart 5 gallon jug, and it is simple 3/4'' pipe thread. Replaced it with a plastic hose bib, and now I can drain my grey water without any drips or mess.
