Originally Posted by nekkidist
My A122 microwave quit working. Shows time and will accept cooking times, but won't start. How do I remove the microwave to replace?
With the camper
unplugged, remove the four screws on the front cover and slide it out. There is sufficient power cord for it to sit on the floor while you check the fuse.
But before you pull it, do check the latch to make sure it is not improperly signaling the door is open. While RV appliances are more expensive than home units, it still may be cheaper to replace than repair. Call your dealer about the cost and call the manufacturer about other resources.
