Old 06-05-2016, 01:51 PM   #1
More Water
We were out for four days (boon docking) and the campground had one water place to fill your trailer tank.
Once you have your trailer all set up and need more water in the tank what do you?
The angle of the spout is difficult to pour water into... ideas.
JoArt is offline   Reply With Quote
Old 06-05-2016, 02:05 PM   #2
I carry one or two 7 gallon fresh water containers purchased at Wal-Mart. I purchased a 12V pump (about$35.00) from Harbor Frieght, set up some 12V extension wires. I use my regular fresh water hose on the input to the pump and a cut down piece of hose for the output into the rig. No need to lift and pour in 56 pounds of water. Works great and the pump has enough power to pump up several feet.
Something like this
12v Marine Utility Water Pump
Or this
12 Volt Marine Utility Water Pump
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 06-05-2016, 02:10 PM   #3
Ford Idaho's Avatar
Depending on what/how you fill your tank.
Camco RV Fresh-Water Tank Filler - 5/8" Diameter Camco Plumbing CAM40023
Another option is a second water pump wired up to fit the four pin connection of your TV.
Old 06-05-2016, 02:17 PM   #4
Butch Wilson's Avatar
We freeze ice for the coolers in a couple of one gallon milk jugs, use the melted water for coffee. Then anyone making a trip to the bathroom has to bring back 2 gallons of water. The milk jugs are flexible enough to force the top into the fill spout. You can pour in all except the last few drops. Nuthin fancy, but it works and requires minimum effort.
Butch Wilson is offline   Reply With Quote
Old 06-05-2016, 05:09 PM   #5
I use this. Spout fits right into camper water fill.
Ozark Trail Desert Patrol 6-Gal Water Jug - Walmart.com
mzak is offline   Reply With Quote
Old 06-05-2016, 07:24 PM   #6
I've been dealing with this for the past month. I have an "X" folding aluminum table that is just higher than the fresh water intake. I use an Aquatainer, the spout is replaced by a mpt to mht converter then with a short piece of hose connected to a camco fill spout. It drains slowly and incompletely, but that's no problem.
The table does double duty as the side table to my camp chair. I also have a smaller plastic "X" table for outside dish washing.
I tried to use a water bandit at a forest service park but couldn't get enough pressure to open up 50 feet of collapsible water hose.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-05-2016, 07:26 PM   #7
I went on my first trip last week and couldn't tell you how many times I filled my 6 gallon water can. I got a 30 gallon plastic tank for the back of my truck and a pump now so it should be much easier.
2016 Coachmen Apex 288BHS
2015 F150 Sport 4x4 3.5 Eco Boost
4B11T is offline   Reply With Quote
Old 06-06-2016, 03:23 PM   #8
I cut the top half of a one gallon plastic water jug off and used it as a funnel for pouring water into the FWT. You can use all kinds of containers to fill the funnel.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 06-06-2016, 03:36 PM   #9
We have a water jugs similar to this:
Igloo Cargo II 6-Gal Water Container - Walmart.com
After the initial fill of the tank with a hose and parking the trailer we just use it once or twice a day to keep the tank topped off.
keith_h is offline   Reply With Quote
Old 06-06-2016, 04:23 PM   #10
bikendan's Avatar
We primarily dry camp so this isn't unusual for us.
Just use a 6 gallon water jug from Walmart.
Looks like a plastic jerry can.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
water
