Old 09-14-2015, 05:00 PM   #11
A nice looking solution. Thanks for posting.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 10-01-2015, 10:07 AM   #12
I made a bracket and bolted it up to the metal ledge on the wall. made some hooks on the back of the tv out of aluminum for easy on/off. works real well.
sinbad85 is offline   Reply With Quote
Old 10-04-2015, 04:00 PM   #13
couzi's Avatar
handbuilder where did you buy that shelve and does it fold
couzi is offline   Reply With Quote
Old 10-04-2015, 09:36 PM   #14
picts of mount
ID:	90690   Click image for larger version
ID:	90691   Click image for larger version
Old 10-04-2015, 10:59 PM   #15
Originally Posted by sinbad85 View Post
picts of mount
How and where do you connect to antenna? Is it indoor or outdoor antenna?
mzak is offline   Reply With Quote
Old 10-05-2015, 06:54 AM   #16
chuck9997's Avatar
Sinbad85 that's a clever idea! Good job.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 10-05-2015, 08:45 AM   #17
Very nice. How is it secured to the top edge of the side wall?
Tom
2012 Rockwood A122S
Old 10-05-2015, 04:18 PM   #18
Sheet metal screw like the one one the front edge. The front screw is a factory one.
Old 10-05-2015, 04:25 PM   #19
I only use the TV with a hard drive with movies on it. I just have a USB cable hanging down to plug into. I guess you could hang an antenna and run the cable through the window.
Old 10-05-2015, 05:31 PM   #20
Very nice install! I have been mulling over how to get my 24" up off of the counter in my pop up. Have settled on using the tension shower rod method but am trying to figure out a nice clean way to attatch the tv and bracket to the rod. This method could be modified to work.
61cubby is offline   Reply With Quote
mount, television
