Old 10-10-2015, 11:13 AM   #21
Originally Posted by Dsfast View Post
Just towed my 128s across from Calgary to the Kelowna yesterday got 14.2/100 litres on the average here it a pic of my rigAttachment 91108 it's a 2013 f150 Eco with 355 gears . I obay the speed limit in Canada
Dsfast, did you mean 14.2 litres/100km? This would be equivalent to 16.5mi/gal. in the U.S.
mzak is offline   Reply With Quote
Old 10-10-2015, 06:13 PM   #22
Hmmm...towing a 3500 lb rig will impact mpg
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 10-11-2015, 08:47 AM   #23
Dsfast's Avatar
Yes I did mean 14.2/100 km I was very happy with that. A lot better than the ford ranger that I used to tow with
Dsfast is offline   Reply With Quote
Old 10-11-2015, 09:18 AM   #24
Dodge Guy's Avatar
The Dodge V-6's of those years were never really designed for towing, that and I'm sure it has a 3.55 gear in it.....none of it good for towing, even light trailers. Believe it or not a V-8 from those years will get better mpg's than what you get now, albeit maybe only 1 or 2 mpg but still better!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 10-13-2015, 09:32 PM   #25
amblt's Avatar
Do you mean 14.2 L/100km? If so, that sounds good to me- there are a lot of hills on that route, are there not?
amblt is offline   Reply With Quote
Old 10-14-2015, 03:56 PM   #26
Last weekend was our 4 day trip to Lincoln, Nebraska from Colorado Springs (540 miles) and back. Here are our data points.
For the 1st time ever towing, got over 22mpg for the first tank of fuel (Colorado Springs to North Platte). The 2nd tank (North Platte to Lincoln) was 20.2 mpg.
On the return, I saw 14.8 mpg from Lincoln to North Platte, 15.1 mpg North Platte to just east of Denver, and 19.2 around Denver and home to Colorado Springs.
Speeds were a pretty consistent 65-67 MPH on interstate highway for all but a few miles. Normal mileage for our minivan (not towing) is 22-23 mpg averaging 5K-6Kft altitude. In Nebrasksa, normal mileage is 21-22 mpg.
Based on the experiences of this trip and others, I have concluded that the factors affecting our fuel economy are (in this order):
1) wind - by far the biggest effect, can change mileage by 40%.
2) altitude - I seem to see 10% improvement for each 5K ft of altitude
3) outside air temp - warmer is better, even with air conditioning, but just enough to notice
On the way to Nebraska, I had no wind to 10 MPH tail winds with temps rising from about 50 degrees (we left at 5AM) to close to 70. On the way home, we started with 25-35 MPH NW (close to head winds), that decreased to about 10-15 MPH as we approached Denver. Temps peaked at 77 degrees at Denver. Winds from Denver south to Colorado Springs were on our tail, but it's a climb from 5,200 ft to 7300 ft in 50 miles.
I'm glad I'm not towing a high wall - I believe the extra frontage area would make a noticeable difference to our 6 cylinder minivan. And I can barely see over the standard height out the rear view mirror.
Fred W
2014 Rockwood A122 - tow weight averages 2800lbs
2008 Hyundai Entourage - minivan, 3.5L V6, 250 HP, 5 speed transmission
Old 10-14-2015, 04:39 PM   #27
accumack's Avatar
Speed is the biggest factor. keep it below 60mph Ideally 55mph Drag is the problem. Never exceed 65mph as that is the limit on the trailer tires. My diesel pusher got a high of 15mpg avg 10.2mpg low of 8mpg crossing the continental divide. I had a 2009 Dakota with the V6 manual transmission the best I got empty was 16 mpg my buddy with a3500 diesel fully loaded got 16.5 mpg.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
frame, mpg, towing, a-frame
