Old 10-10-2015, 06:39 PM   #1
My fantastic fan opening tool
I must be vertically challenged because I can't reach the knob to open my fantastic fan. I even have trouble reaching it from a step stool. Obviously a tool was needed.
I made the tool from the following materials:
3/4" PVC pipe, length to suit (I think I made mine about 32" long)
3/4" PVC pipe coupling
1" PVC pipe coupling
3/4" PVC pipe cap (to finish the bottom end)
PVC cement
I took the knob off of the fan and traced around it on a piece of paper so I would know where to cut the notches in the end of the 1" coupling. After cutting the 4 notches, try it on the knob before gluing everything together. You want a loose fit on the knob.
It is light weight, works great and stores easily.
ID:	91158   Click image for larger version
Joe in NH
2016 Rockwood A192HW A-Frame
2013 Ford F-150 XLT 3.5 Twin Turbo Supercrew
Swampweasel is offline   Reply With Quote
Old 10-10-2015, 06:51 PM   #2
WOW, you get an award for that ! I am pulling out in the morn for Lake Wateree SP, Winnsboro,SC then on to OH or I would be at Home Depot now, geez!
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 10-10-2015, 10:27 PM   #3
Terier's Avatar
Great idea! I know this isn't hard to make but if you ever go into business with selling this item I would be a customer.
Old 10-11-2015, 12:02 AM   #4
Nice job! There is a product out there called a "vent stick". It comes with a new vent handle with a "D ring" attached and and a pole with a wire hook on it. Been using it for about a year. My wife is also vertically challenged.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 10-11-2015, 07:06 AM   #5
Hi Bob
I didn't know about the Vent Stick. The reviews for that say their knob is too long for use in an A-frame because it interferes with closing the roof.
My design uses the existing knob, is much less expensive, and fun to build!
Joe in NH
Old 10-11-2015, 09:00 AM   #6
Now figure out how to attach it to a cordless drill and you will make a fortune!
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 10-11-2015, 09:26 AM   #7
Nice job! Now if it would only work to turn the fan on/off (I have an all manually operated fan).
rjwilder is offline   Reply With Quote
Old 10-11-2015, 11:36 AM   #8
Thanks TJ
I can reach the lock and the on-off switch from the floor, so I guess I am only semi vertically challenged! I just couldn't reach the cover opening knob.
Joe in NH
Old 10-11-2015, 11:52 AM   #9
Fan Opening Tool
Great idea. Off to Lowe's!
lclayton is offline   Reply With Quote
Old 10-11-2015, 12:18 PM   #10
Need to send this into Trailer Life for their "10 min Tech" column
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
fan
