Old 06-24-2013, 01:22 AM   #41
handbuilder's Avatar
I keep a 12v adapter in mine at all times
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 06-24-2013, 06:31 AM   #42
Originally Posted by thehamguy1 View Post
The clearance between the jack and my tailgate (when down) is about half an inch, and only when the whole unit is straight. I think the only reason I have that much clearance is that the ball mount sticks out of the hitch receiver about three inches more than it needs to. So maybe you could look for a slightly longer ball mount-?
Thanks. Than is a good idea, I'll look into a longer ball mount.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-24-2013, 06:48 AM   #43
Originally Posted by elmonsanto View Post
This is just what I need. I now have a very basic electrical question. What is the correct way to connect my new wire to the wire going to the fridge? Thanks!
I am no expert on this, but...the more difficult the method of connection, the better it will be.
The best way is probably solder. The second is to cut the wire and use crimp on splices.
The least good way is to use "snap on" splices that do not require cutting the wire. They will work but are prone to losing the contact. But if the connector is easy to get to it can be repaired quickly. I used these to get power for the fridge compartment ventilation fans on my old Niagara without incident. YMMV
An examination of your fridge may find a more suitable way.
Tom
2012 Rockwood A122S
Old 06-24-2013, 08:51 AM   #44
Mostly Harmless
thehamguy1's Avatar
If the 2" square tubing of your present ball mount is long enough, you could try moving the hole for the hitch pin farther back. BTW, the suggestion to use the fridge wiring is genius. It would have to be substantial wiring to handle the fridge's current demands, though I've never looked at it.
No wonder the folks in your previous popup's owners group miss you.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 06-24-2013, 10:05 AM   #45
Thanks for your kind words. Most of what I know is gleaned from people who really know their stuff. I just remember it well.
Of course, when tapping into the fridge power line, one should know the fuse amp rating of the circuit and use wires and outlets with the same or greater rating. Or a inline fused outlet. Without being able to look at the converter right now, I'd say my fridge circuit is on a 15 amp fuse. So that would require only 14 gauge wiring.
Tom
2012 Rockwood A122S
