10-17-2016, 04:38 PM
Need advice regarding draining water heater
Hi all!
In preparation to winterize our 2016 T12BH, I'm a little confused about the water heater.
Specifically, I'm unclear about the by- pass valve. It's purpose, and how to use it.
I need to get a 1" 1/16" socket to remove the anode rod to drain the water heater.
**Does anyone have a step by step process (or a link to one!) for draining the A-frame.
It should be fairly simple, it's just I've never done it before. There isn't a toilet, or P-trap to deal with, so it just draining the supply lines and water heater.
Thanks for your help!
Russ
2016 Flagstaff T-12BH A-frame camper
Livin' the dream!
10-17-2016, 05:49 PM
Originally Posted by Russ in CO
Hi all!
Russ
Close the two lines going into the tank.....red and blue.....the handles should look like they cross the lines........the bypass valve should be the opposite it should be inline with the line. Any water/fluid that comes that way will bypass the tank. Drain the tank by removing the anode.....inspect anode to look for excessive wear, replace if necessary. when replacing anode......wrap a few turns of white teflon tape around threads before replacing.
10-17-2016, 07:13 PM
And be sure to open the preasure relief valve at the top of the tank before you remove the anode.
10-18-2016, 05:07 AM
If you are just draining, release the pressure by either opening a hot water faucet or the pressure relief on top of the heater. Then unscrew the anode rod. When you replace it, be sure to use some teflon tape on the threads.
If you need a check on the bypass to be sure the WH is isolated, try pumping some water through after draining the WH tank. If the bypass is correct, water will flow out the hot water faucets, and not out the anode rod opening.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
10-18-2016, 03:47 PM
Canadian Member
This may help for the valve positions when by-passing.
When I empty the WH, I leave the pressure relief closed until after I've removed the anode so it doesn't flow full force when I'm standing there. I find it's easier to open the pressure relief valve from the side to avoid getting wet.
10-18-2016, 04:42 PM
Thanks all...
I just picked up a 1 1/16 socket, and I'm gonna get after it.
I'm sure I'm not the only one getting ready to do this, so keep the great suggestions coming!
Livin' the dream!
10-18-2016, 04:50 PM
The main function of the bypass valves is to divert the antifreeze from entering the H/W heater.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
10-18-2016, 07:26 PM
Pockets
Here is an excel spreadsheet copied over to a word doc. I use this to winterize every year. Good luck buddy
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew XTR 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg 2015(36 nights) 2016(74 nights) 2017(174 nights) 2018(157 nights) 2019(79 nights) 2020(108 nights)
10-18-2016, 09:16 PM
You also have the option to drain at least 90% of the water in the heater by just leaving the bypass system in "Normal Use Mode" while you drain the rest of the system with the 2 low point drain valves and the hot and cold knobs on the sink faucet full open. Even if the small remaining amount of water in the heater freezes, it is in an un-restricted area and will not cause any damage.
After fully gravity draining, set the heater valves to bypass and add antifreeze to the system. Don't forget to drain the freshwater tank, add anti freeze, and then run the pump to push the antifreeze through the system. You should remove the water filter element before this if you plan to use it again next season. Personally, I replace the element every spring when de-winterizing.
Also, don't forget to purge the outside shower circuit. I use 3 gallons total of anti-freeze when I do my T12.
10-18-2016, 09:35 PM
Lots of You Tube videos on the subject. Do a search for one close to the same RV that you have.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
10-19-2016, 10:46 AM
Just leave the pump off and open a hot water faucet, BEFORE you isolate the heater with the valves. I was a plumber for many years, and those things dont like to be treated like an on off switch. They can develop leaks if you dont just leave them be.
2016 212HW led valiantly into the beyond by a 2010 Track Edition Ford Ranger 4x4.
Nights camped 2016: 14
Nights camped 2017: 11 (so far)
10-19-2016, 10:56 AM
Excellent diagram - thanks for sharing!
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
10-19-2016, 12:05 PM
OK, I think I got it done.
A couple things I don't think were mentioned in case someone else refers to this thread:
Check the under sink filter canister. We didn't install the filter, yet the canister was full with water, that didn't get removed with air pressure, or opening drain valves.
For some reason, I didn't think the sink had a p trap, since there isn't a grey water holding tank on our unit.
I couldn't seem to remove the trap to drain it, so I blew air into the sink drain, and the water came out the side of the A frame drain.
I think I'm done!
Please leave more comments for the future new A frame owners.
Thanks again for the help!
Livin' the dream!
12-14-2016, 09:59 PM
Just winterized my 2016 T21TBHW using the compressed air method. I have always hated filling the lines of my Jayco camper with antifreeze because it takes so long to flush the sytem and we have several trips down south planned this winter.
In addition to draining and blowing out all the lines and removing and draining the cannister filter I found a small, for lack of a better description, sediment bowl attached to the water pump. It did not drain. Look for one on your system. It was not described in my manual.
Finally i disconnected th water line at the water pump and found it full of water that did not drain.
Perhaps these wold not have caused problems but better to be safe.
