Old 05-05-2015, 08:23 AM   #11
kdot's Avatar
Exclamation Questions
Well, I'll be darned; didn't know such a thing even existed!
Kent
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 05-05-2015, 09:18 AM   #12
RedLdr1's Avatar
I'm always reminding my wife that a RV, or a Harley, is nothing but the equivalent of a "Barbie Doll" for "grown up" boys. The initial cost is just the beginning, it is the accessorizing that is really expensive!
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 05-05-2015, 09:55 AM   #13
kdot's Avatar
Questions
So it is. I'm in the process of rigging an HDTV antenna into the unit to get TV weather/news when we are away from the stations. I have an antenna, have hooked it up and discovered that it works, pulling in stations over 30 miles away. Now I have to rig the trailer so that it's quick and easy to put up and take down the antenna. Then I think we're home not quite free. Got about $45 invested in it.
Kent
2017 RPod179
2016 Honda Pilot
Old 05-06-2015, 02:22 PM   #14
Originally Posted by mickrock View Post
so, if you drain out all of the water from the main water drain line valve, does the hot water tank remain filled with water?
It looks like removal of the anode is the only way to drain the hot water tank...
Make sure that you open the pressure relief valve on the top of the heater before removing the anode or you will get a refreshing bath...I drain the heater after every trip - the water in the heater can get pretty foul smelling if it sits there for a long time.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 05-07-2015, 07:42 PM   #15
Question about the H
About that Hott Rod replacing the anode -
Since the anode serves a purpose as a "neutralizer", if you switch to a Hott Rod, what happens to that neutralizing? Is it handled by the Hott Rod, or lost?
mickrock is offline   Reply With Quote
Old 05-07-2015, 07:52 PM   #16
RedLdr1's Avatar
The Hott Rod acts as the anode. Since it is stainless steel you need to clean it off periodically with something like CLR. Or you can buy a replacement heating element as necessary.
Wayne and Christine
a122, a-frame
