Old 01-17-2013, 10:22 PM   #31
2Susan's Avatar
I can't speak to the route questions but two things come to mind.
1. They have stores where you are going. If you aren't sure need something why not wait and see? For example your electrical extension to the campsite hook up - doesn't sound like you will need one this trip. Waiting allows you time to consider differences between what is available as well as comparing prices. You might want to consider a nifty (bit expensive) gadget that cuts power to your rig if there is an electrical surge, and notifies you of ungrounded / backward wire service polls. Search this site for discussions on these
2. drinking water hose. Again you should be fine with a 25 ft hose for this particular campsite, but I would suggest getting better than the basic cheapo hose. We had nasty tasting water until upgrading the hose. You might find too that two 25' hoses are easier to handle than one long one. Not so much to have to drain and re-roll for most of your stops. We also have a non-drinking water hose (one of those that self coils and is light weight). I bring a container of bleach to swab off the faucet, ends of the water hose and connection to the rig before connecting.
Now some suggestions you might not have considered:
1. bring tools so that you can do minor repairs - such as remove replace a faucet or electrical switch, tighten screws, etc. You'll find something that needs adjusting!
2. purchase an inline water filter (find them at Walmart in the RV section) that attaches to your hose before the water goes into your rig. Traps the sand & sediment and crud that might otherwise clog your faucet areators
3. Do not buy black tank chemicals - you do not need them at all. Just make sure to flush your black tank well when you empty it - and do not leave the sewer connection open while you are in the campground. If you do you will have a pyramid of the solids drying out. Water is your friend in the black tank!
4. When you pick up your rig, check the dates on the batteries and get them to swap them out for newer ones. Rigs on the lots often have abused batteries - showing the units to potential buyers I think the batteries get run down and not recharged appropriately and damaged.
5. Before you leave find the fuses and pick up some spares - doesn't take much room and handy to have. Along those lines I also suggest good flashlights and plenty of batteries.
I also suggest running water through your new hose before using it - gets rid of the chemical smell / flavor. At home if you can hook it up to a bathroom sink and fill the tub for example you'll have rinsed it pretty well.
2Susan is offline   Reply With Quote
Old 01-17-2013, 10:45 PM   #32
lotsip's Avatar
Great suggestions Susan!! Gonna return the 50' hose and get a 25'. also gonna return the extension cord...thank God for walmart's return policy, plus I think they have plenty of walmart's and rv's store down south Will definitely get the inline water filter, and I always carry tools, and have no black water tank on my rig. I bought a '12 leftover, but, still new, i bet that battery is worn down some.......I'm also guessin the RV dealer will squack with I ask them to replace it, ha, but, will try.
lotsip is offline   Reply With Quote
Old 01-18-2013, 03:31 AM   #33
We use a 22 inch flat screen and set it on the counter top above the microwave. I made a small U shaped shelf that the TV sits on so I can put a DVD player or satellite receiver under the TV. I don't think you'll have much luck picking up local channels with rabbit ears. I bought an omni directional antenna and put it on a pole and I still get a limited number of channels. Some campgrounds are better than others. I've seen other threads about different antenna setups. I don't use a satellite system on the road, but I do record a ton of movies and TV programs on my Dish network receiver, then take the receiver with me and play back my recordings.
For internet we have an IPad that can go Wi-fi or 3G. We can do practically everything on an iPad that we can do on a laptop. Older iPads probably could be found dirt cheap, I imagine, but I haven't really looked into that.
I hope your vehicle is set up with an electric brake controller and proper trailer connection.
The slime air compressor is a good emergency unit to have around. I got it to take on motorcycle trips, which came in handy, but I haven't needed it while camping. The Slime unit is good since it comes with different connectors. The cigarette plug may work but it may not be located near the problem, and it may blow the fuse in the vehicle. Alligator clips can be connected to the trailer battery, and the battery can be moved to where you need it.
toleworks is offline   Reply With Quote
Old 01-18-2013, 08:19 AM   #34
lotsip's Avatar
Thanks so much for the wonderful tips ! I was thinking 22" TV......but, now u got me thinking of at least a 26". Am gonna start with some kind of antenna and hope for the best in Florida, if I get sick of crummy reception, I can pick up a Dish Network weekender package at any of the Camping World stores in Florida.
I thought of an IPad, but, not sure if I want that expense....already have a laptop, so, was kinda thinking of the Verizon Jetpac with a monthly data plan, we'll see.
Picking up my a122 today and the rv dealer is installing a Voyager electric brake controller in my Tacoma. I've trailered boats for years, so, there is some carryover knowledge there, hopefully.
I'm gonna ask the RV dealer today what they would recommend, I want to make sure I get a compressor that's powerful enough to blow out the water lines .
Thanks again for the help !
Old 01-19-2013, 04:31 PM   #35
lotsip's Avatar
YAY, big day! Set the camper up in my driveway, got the camper level, then had to run to the hardware store for a male to male 3/8" bit for a 3/4" socket to put the stabilizers down with my drill !, But, that made it a lot easier....... The sides went up easily, just have to be careful with that door !...plugged into my outside 110v outlet with a 30amp to 110v adapter they gave me at the RV dealership yesterday, and turned on the propane....my friend bill came over and we got everything working....took a while to figure out the Dometic thermostat, but, finally did, and the Cool cat worked, heat or AC, as well as the furnace, stove, microwave, stereo, put the refrigerator on propane, worked fine.....all in all a great day....!! I took more pics...!
New Camper Pics Photos by pcr1125 | Photobucket
Old 01-19-2013, 04:55 PM   #36
Rockwood Premier A126
gregory's Avatar
Lookin' good! Are you sleeping in 'er tonight? Exciting stuff
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 01-19-2013, 04:59 PM   #37
lotsip's Avatar
Deb
Hahahaha, I was actually thinkin about it !.....(sounds like you been there before, Deb )
Old 01-19-2013, 05:08 PM   #38
TRAVELINBOB's Avatar
CONGRATS, LOOKS GREAT! Enjoy, tip I have seen listed on the sight that maybe is not mentioned here, 24 hours before you leave hook up shore power and turn the fridge on 120, then hook her up to the car, switch to 12v while driving, unhook from car to prevent draining vehicle battery at night, should be cold when you arrive at your destination!
2016 BIGHORN 3760EL
2016 F150 SC ECO BOOST
2017 SUZUKI KINQQUAD 500 EPS
TRAVELINBOB is offline   Reply With Quote
Old 01-19-2013, 05:13 PM   #39
lotsip's Avatar
Thanks Bob, I am already in LOVE with my a122, so cozy, and so many toys in it !
Thanks for the refrigerator tip, not sure if i will have anything to put in the fridge, but, if I do, your tip is a great one !!!
Still don't know when i am going, sometime after my doctor's appointment on monday.......haha....should be within a week or so after that......not sure of the route yet, might stay in the Panhandle for a few days at first, got a couple park tips there from Deb, and they don't look like they fill up.
Old 01-19-2013, 05:27 PM   #40
remember if you put a bunch of not so cold stuff in it and its not already cold it will take forever to GET COLD, best to Pre-cool it,,,the SPACE POD as I call it is sooo cool! you barely need a fridge :>)
2016 BIGHORN 3760EL
a122
