Old 12-24-2015, 08:55 AM   #21
chaviva7's Avatar
Name:	ImageUploadedByForest River Forums1450968901.718682.jpg
Here is what our A-Frame looks like. It's the one with the Hardside dormer.
chaviva7 is offline   Reply With Quote
Old 12-24-2015, 09:15 AM   #22
Wolverine 1945's Avatar
Originally Posted by chaviva7 View Post
Attachment 96733
Cute !!!
Wolverine 1945 is offline   Reply With Quote
Old 12-27-2015, 08:45 AM   #23
chuck9997's Avatar
Someone called my ROCKWOOD a122s "cute".. I punched them in the mouth!
just kidding.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 12-27-2015, 06:50 PM   #24
Butch Wilson's Avatar
ID:	96852We have the Flagstaff t21qbhw no problems !
Butch Wilson is offline   Reply With Quote
Old 12-27-2015, 07:07 PM   #25
chaviva7's Avatar
Butch have you had any hard rain or winds when you camped? We have the AFrame with the dormer and the roof is a bit taller than your Aframe. We did have the HW 194 Rockwood with no leaks at all. I think our issue was because of the high winds and rain that pushed up the rain underneath the lip.
Old 12-27-2015, 07:41 PM   #26
No leaks with rain, not sure what high winds would do ! Ours has the electric lift I do have to lift up slighty on the front side for it to settle when fully upright ! i can't see any crack at all inside between the two surfaces !
Old 12-27-2015, 08:14 PM   #27
I could see where a driving rain head on to the back roof could drive water between the two sections ! Have you tried using the garden hose to check for leaks ?
Old 12-28-2015, 08:41 AM   #28
kdot's Avatar
New camper roof leak
Chaviva7, this may be a stupid question, but I'll risk it. Are you sure that when you raised the roof that the entire edge of it all the way across settled into the "notch" for it? I've discovered with our A213 that the side of the roof with the actuator goes right in, but I have to give the starboard side of it a little extra push by hand to get it in the notch all the way across. If the back part of the roof is not all settled into the notch on the front roof, that would leave room for water to be blown inside. Just a thought.
dot
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 12-28-2015, 09:32 AM   #29
chaviva7's Avatar
dot
Kdot I thought about that and hubby says it was all the way up. He did note that in the roof from inside the foam rubber was a little uneven. He's not sure if it's just because it's very new or a flaw. Though the rain the day before was no problem. No leaks.
Old 12-29-2015, 05:34 AM   #30
I will admit I know nothing about these A farmes,,,
But I am guessing they must be VERY level in order to close property ???
camper, leak, roo, roof
