New found water leak
Hi all,
I have a Rockwood A122, 2013 model.
In mid-cross country jaunt and hooked up, once again, to a pressurized water hook-up in a campground. Within minutes, saw water overflowing outside under the city water input. Looked under sink and found some water on the floor around where the pump is located.
Decided perhaps the water pressure was too much for my little camper (I did have a simple 45psi regulator attached), so I filled my fresh water tank and turned on the pump and more water flows in.
No leak around the filter. It seems to be coming from somewhere either behind the pump or in the pump itself.
The pressure at this campground is incredibly high.
I've been using city water hook up for 9 days on this trip and this stop is the first issue I've had.
Could the pressure have caused a leak somewhere, even with a regulator? Any other thoughts?
Thanks.
