08-06-2016, 05:13 PM
New generator project
Working on a new project !
Butch Wilson
2016'Flagstaff T21QBHW A-Frame
08-06-2016, 05:26 PM
Used a modified cargo carrier as a platform .
Butch Wilson
08-06-2016, 05:56 PM
Looks good does that limit you to one battery
Retired Navy
2016 Flagstaff 26 FKWS
08-06-2016, 07:09 PM
The platform can be configured from 30 inches to 60 inches. I am currently at 34 inches. By expanding it another 3 inches you can turn the batteries sideways and get 2 in the tray.
Butch Wilson
08-06-2016, 08:28 PM
Have you checked your tongue weight? It appears that the propane tanks have been moved closer to the tongue jack. With the extra weight of the generator you may have overloaded the tongue. It's worth a look.
2017 A212HW
2016 Ford Explorer TV
The Villages, Florida
2019 Puma 255RKS 5th Wheel
2013 Ford F-150 w/ max tow
08-06-2016, 08:34 PM
2017 A212HW
We'll see !
Butch Wilson
08-07-2016, 07:40 AM
when I get my A213H next year -- just before retirement.. I plan a mod to the back of the trailer that will put a re-enforced carrier place that would hold generator etc .. up to a reasonable weight - versus having that weight in the front...
also thinking of 2 honda 2000 generators in parallel us - use one or two depending on need -- so not to have such a heavy single thing to lift and move around
I also plan a significant battery and solar mod -- that will add some front weight
I would like to have a more beefed torsion axle and lift to have larger tires.. but will definitely get some really good - high weight rated tires..
also not sure -- I want the smaller bubble windows on the front..
I think a A213H with a front dormer and a toy hauler area in place of the storage box would be an awesome model of a-frame -- maybe just a bit longer and have just a bit longer twin beds...
anyone with an A213H -- using it in king bed mode -- how does the location and controls of coolcat work in that mode -- ok, not so well under the bed area??
TV is a 2016 GMC yukon 4x4 with full tow package so TV can handle quite a bit of tow and tongue weight..
08-07-2016, 08:57 AM
Originally Posted by stevetoney
anyone with an A213H -- using it in king bed mode -- how does the location and controls of coolcat work in that mode -- ok, not so well under the bed area??..
My rig has the same bed setup...when bed is set up, it creates a 3 foot "dead space" under the bed which inhibits flow of air from CoolCat. One way to help compensate for this is to turn on the roof fan which will help move air better throughout the trailer.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
08-07-2016, 09:26 AM
yes -- it does seem an issue that would warrant some redesign and move the coolcat to work better in king mode...
08-07-2016, 09:33 AM
The coolcat works well on our unit with the King bed layout ,of coure there are no controls on the unit, all controls are on the thermostat. My one inconvenience is the person sleeping on the backside gets no fresh air at all when not using air conditioning. The dw gets all grumpy when you get up and have to crawl across to get out of bed through the narrow opening as well. I guess everything is a compromise.
Butch Wilson
08-24-2016, 11:45 AM
Butch,
Where did you get the cargo carrier? I've looked online and only found hitch mounted types.
Thanks,
Tim
2017 A212HW
08-25-2016, 09:39 AM
Originally Posted by Butch Wilson
I modified this one from Northern Tool. No welding but you will need a drill and a side grinder with a metal cutoff wheel.
Gotcha! Thanks. Looks like something I could even do. I'm assuming you used the grinder to cut off the hitch portion.
How did you secure the generator to the carrier?
2017 A212HW
08-25-2016, 11:12 AM
2017 A212HW
Actually I used the grinder to modify the mount for the lp tanks so they can move forward to make room for the carrier. You will need a longer gas line and u-bolts to mount the carrier. The carrier comes unassembled you never mount the hitch portion. The two narrow bars from the kit slide through the channels on the bottom of the generator and mount to the carrier. Good luck. I have not weighed it yet, however I have towed it around for a while with no ill effects.
Butch Wilson
