Old 08-19-2012, 03:29 PM   #1
FarFromStock's Avatar
New interior lights for the A-frame
We decided to change the interior lights so that each side of the fixture could be turned on independently. Found these on amazon and they work wonderfully!!!! Installed the LEDs we had purchased a couple weeks ago, and I'm a happy camper!!! (pun intended!!)
ID:	18340   Click image for larger version
ID:	18341   Click image for larger version
ID:	18342   Click image for larger version
...and...we're camping!!
Glenn & Debbie
2013 Rockwood A127TH (aka Carl)
2012 Ford Raptor
Camping born-on date: 21 July 2012
Nights camped: 2014-3 (so far!!); 2013-16; 2012-2 nights
FarFromStock is offline   Reply With Quote
Old 08-19-2012, 03:41 PM   #2
Rockwood Premier A126
gregory's Avatar
Very handy, gives you options! Job well done.
I actually took a bulb out of one "side" of each fixture to "tone it down" a bit. I would like to get some the LED bulbs too. They seem to be a little pricey...
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 08-19-2012, 03:56 PM   #3
handbuilder's Avatar
Thats awesome! What was the part #/name?
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 08-19-2012, 08:59 PM   #4
Bargman Lights 34-76-243 76 Series 12V Double Interior Light with Dual Switch
Glenn & Debbie
2012 Ford Raptor
Old 08-19-2012, 09:09 PM   #5
spierce617's Avatar
What are you using for led lights and where did you get them?
1999 Chevrolet Suburban 5.7L V8
2005 Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 08-20-2012, 06:07 AM   #6
We ended up purchasing 2 each of the 921 and 906 LED bulbs from eBay. The 921s are just slightly brighter. We used one of each flavor in the interior overheads, and they work fantastically.
Here are the 2 types of bulbs we bought:
921 LED Bulb, Bright, Warm White, 24SMD5050 bulb, T15 wedge base
906/921 LED Bulb, Bright, Warm White, 13SMD5050 bulb, T15 wedge base
Glenn & Debbie
2012 Ford Raptor
Old 08-20-2012, 04:15 PM   #7
Much thanks for the dual light switch details!
Old 08-20-2012, 05:39 PM   #8
Just a note about these led lights. If any of the individual LEDs burn out, remove them and replace the entire bulb. A good friend of mine nearly had a fire in their camper due to this issue. Stick with the tried and true ... for safety sake.
i certainly like the idea of the double switching tho ... excellent.
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 08-20-2012, 06:12 PM   #9
Thanks for the safety tip D-mo!!!!!!
Glenn & Debbie
2012 Ford Raptor
Old 08-20-2012, 06:53 PM   #10
Greyhawk's Avatar
d-mo
@ D-mo; Are you suggesting that we stay with the incandescent bulbs? Suggesting that the LED are unsafe??
@ FarMoreStock; Thanks for the information, both the light and the LED bulbs.
Reason being; we just purchased a 2013 V-Cross VIBE. It was a floor model and the lights were left on for long periods of time. Consequently, several of the lights didn't work. They thought that the bulbs were burnt out. Fact was, the fixtures were melted from the heat so they put in new fixtures.
I too would prefer the duel controls because the double lights are not only too bright but they get hot pretty quick. I've been searching the web but wasn't sure what was a replacement and what wasn't. I found some LEDs at $4.50 ea. and didn't want to order 1 to see if it fit when I really need 8-10. And I don't need 10 if they wont work.
Grey
TT = 2013 Vibe 6501
TV = 2015 Nissan Frontier.
Greyhawk is offline   Reply With Quote
a-frame
