Old 07-09-2014, 03:13 PM   #1
No 30 amp-Will Air Conditioner Run OK
I read a post somewhere (I think on this forum) that our air conditioners could run on 15 or 20 amp breakers instead of the 30 amp breakers like at rv parks and state parks.
I keep my camper plugged into my 110v at home to keep the battery charged. Yesterday, I turned the air conditioner on just to see if it would work and it turned on....the compressor turned on and the cold air was blowing in just a few minutes.
My grandkids are staying with us Friday night here at home and I thought they would enjoy sleeping in the camper but it's too hot without air conditioning.
My question is would it be ok to run the air conditioner even though it's not 30 amp....not sure if it's 15 or 20 amp...older house. This is not something I would do on a regular basis but would be nice if it works without hurting air conditioner.
David
Tow Vehicle: 2012 Durango 3.6 Pentastar Engine
Total nights camping 2014-(10)
Total Nights Camping 2015-(9)
Total Nights Camping 2016-(5)
Total Nights Camping 2017-(4)
Total Nights Camping 2018-(7)
mlsa3 is offline   Reply With Quote
Old 07-09-2014, 03:17 PM   #2
TURBS's Avatar
Most household outlets are 15 amp rated.
Normal a/c uses 18 amps to start and run 12-14 thereafter depending on how hot it is.
A true 20 amp outlet has one prong vertical and one horizontal.
Old 07-09-2014, 03:20 PM   #3
TURBS's Avatar
I have ran my a/c on a 15 amp outlet with a short cord to the outlet.
Now my outlet was only a foot from the breaker box in my shed and the cord was 20' and 12 ga. Wire.
YRMV !
Old 07-09-2014, 03:57 PM   #4
amps are self protecting. it is voltage drop you should be concerned with. how much voltage is there when ac is loaded and running?
rr retired is offline   Reply With Quote
Old 07-09-2014, 03:59 PM   #5
Timex's Avatar
David
I have done it in the past. If you don't have LED bulbs in your light fixtures, don't turn the lights on. I'm with Turbs on the amp usage. You'll be drawing 12-14 amps with just the A/C running. Then the converter will pull 1-2 amps. You are pushing the limit on amps. Keep the power cord to no more than 20-25' and since you will be using an adapter for the receptacle, make sure the cord fits snug into the adapter and the adapter fits snug into the receptacle. If the cord, ends or adapter get hot, the party's over.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 07-09-2014, 04:01 PM   #6
thestrangebrew's Avatar
My AC will run for a few mins and trip our breaker on the 15 amp plugs outside. Which is weird because when we first got the trailer, we let the AC on for hours while we messed around with things and let my daughter play and watch movies. Never tripped it. Now I can't get the AC to run for more than 10 mins. plugged in.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 07-09-2014, 04:06 PM   #7
Timex's Avatar
You're cooking the goose with all those amps! I'll bet some damage has been done somewhere along the way to the outlet, adapter or the power cord. Do a search on here for the amp list for what each electrical item will pull. It may be in the library section. Print it out and pin it inside a cabinet for future reference.
Old 07-09-2014, 04:30 PM   #8
Oh man thanks! I'll have to find that list!
Old 07-09-2014, 04:34 PM   #9
Timex's Avatar
Try this. Found this on an earlier thread.
normal appliance amp draws
Old 07-09-2014, 04:56 PM   #10
Herk7769's Avatar
FYI - My Colman Mach III 15K pulled 19-22 amps on start-up and about 15.5 amps running prior to installing the fan delay. Now it is 16 amps on start-up (but the peak stays longer due to the fan kicking in about when the compressor evens out.
My 20 amp garage circuit can handle it just fine, but the Yamaha 3000 watt (with 500 watt boost) generator will toggle in and out of overload (boost) as the compressor cycles.
HAM CALLSIGN - KC3FFW
air conditioner
