Old 06-27-2016, 10:05 AM   #1
mudman2's Avatar
No propane
I'm leaving for a 4 day trip. Tried to ignite stovetop to get fuel going no luck. Both tanks have fuel. Was hoping to run fridge on propane on the way. Switch always shows green but still no fuel. Shows green on off position also. I have used propane for fridge before but can't figure what went bad. Any ideas?
2015 t19qbhw
2015 Toyota Tundra crewmax lmtd
2019 microlite 25bds
2015 tundra
mudman2 is offline   Reply With Quote
Old 06-27-2016, 10:36 AM   #2
The safety valves on those tanks can shut off if the ACME nut is not secured just right. Shut the valves on both thanks and make sure all the appliances are turned off. Remove both Acme nuts, wait a minute and reattach. Then open a tank to see if you have pressure.
Understanding Propane Bottle Valves - Troubleshooting LP Gas Cylinder Connections
Second possibility is the regulator leak detection safety cut off. How to reset the regulator.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-27-2016, 10:46 AM   #3
mudman2's Avatar
Originally Posted by Pooneil View Post
The safety valves on those tanks can shut off if the ACME nut is not secured just right. Shut the valves on both thanks and make sure all the appliances are turned off. Remove both Acme nuts, wait about 5 minutes and reattach. Then open a tank to see if you have pressure.
Thanks I'll give it a whirl.
Old 06-27-2016, 11:54 AM   #4
mudman2's Avatar
Pooniel your the man. It worked.
Made my trip a lot easier. Thanks.
2015 t19qbhw
2015 tundra
propane
