Old 05-12-2015, 07:52 AM   #1
noise from hot water faucet
does anyone else get squeeking noise from hot water facuet/how can I fix it? dealer replaced facuet once/it went back to noise after I day trip//////now out of warranty//
2014 A122s rockwood 2014 jeep grand Cherokee v6 290 hp 4by4
ridgeline1 is offline   Reply With Quote
Old 05-12-2015, 08:25 AM   #2
Are you on city water or pump try taking off aerator sounds like it may have something in it
jlroadmaster is offline   Reply With Quote
Old 05-12-2015, 08:37 AM   #3
Shut the water off, relieve the pressure and take the faucet completely apart and coat all parts and the housing with Danco silicone paste and reassemble. Will work on the cold water for about a year, on the hot water about 3-6 months.
Danco Perfect Match 88693 Silicone Grease-GREASE SILICONE - Walmart.com
Name:	Danco silicone paste.jpg
Old 05-12-2015, 12:20 PM   #4
I haven't had the problem but would cast the all plastic faucet in the trash and replace it with a better one from my local orange or blue big box store. I did this on my old camper at the first sign of trouble. Just watch for clearance of the spout when closed.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-13-2015, 12:38 PM   #5
X's 2
Nastyfoot is offline   Reply With Quote
Old 05-13-2015, 03:35 PM   #6
thanks/you are right about the clearance ////
Old 05-13-2015, 11:38 PM   #7
WFD
Can you elaborate on just what you mean by clearance of the spout when closed.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 05-14-2015, 07:40 AM   #8
RedLdr1's Avatar
On A-Frames the side walls fold inward for storage. So you need to make that sure your faucet, and anything else, does not "stick up" above the hinge line or the wall will hit it. Even the OEM faucet in my trailer requires the removal of the "spout" prior to folding down the walls.
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 05-14-2015, 08:12 AM   #9
Jerry01's Avatar
Is the faucet squeaking only when turning the handle or when water is coming out? Our hot water handle squeaked only when turning it. The cold never squeaked. They replaced it under warranty. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 05-14-2015, 08:50 AM   #10
What RedLdr1 said.
The spout on mine if fairly flat and stays attached. So I take it, newer campers have a removable spout? That would make finding a non-OEM replacement very difficult.
Tom
2012 Rockwood A122S
hot water, water, faucet
