There is another thread that I posted with my experiences in getting the 4223 fridge to work
https://www.forestriverforums.com/forums/f221/im-liking-my-a-frame-fridge-104964.html
Thanks to the contributions of others, i finally got there - consistent fridge performance in all weather in all 3 modes.
For your fridge to work well, the heat source has to work and transfer heat to the refrigerant. And the heat must be removed from the refrigerant at the cooling coils. I found on my Coleman pop-up with a similar fridge, that when the fridge is working, heat is pouring out of the top vent. I just couldn't get that to happen consistently on my A122 with the Dometic 4223. A lot I still blame on those Dometic vent grills - they are great for stopping rain, but they pretty much stop any natural convective airflow, too.
Rockwood/Flagstaff's installation doesn't help matters - the space isn't baffled correctly to force the heat out the upper vent. The heat gets trapped in the upper part of the compartment, and the fridge can't cool because there is no air going across the cooling coils unless conditions are just right.
After spending time baffling and restricting the space above the vent and otherwise fixing the install, I finally did what others had gone to - the computer case van pushing air out the top vent.
With that little 120mm, 400+CFM 12V computer case fan (.07 amps), my performance issues were solved. I could feel the heat pouring out the top vent. When the fan was stopped, performance was just as inconsistent and unpredictable as before. With the fan, I started having issues from freezing contents in cool mountain weather. - even on lowest propane or AC settings. Fan would have to be turned off.
When towing, the wireless thermometer proved to me that the propane flame was being blown out within 2 hours at highway speeds. I ended up towing with fridge on 12V - had to switch the fridge on and off to stop from freezing contents on 70 degree days.
With my High Wall A-frame, I'm still having occasional poor fridge performance. I'm about to install 2 computer case fans and remove the Flagstaff fan - which is noisy when it comes on.
just my experiences
Fred W
now 2019 Flagstaff T21TBHW A-frame
prev 2014 Rockwood A122 A-frame
