Old 04-26-2016, 09:47 PM   #1
mollypcb's Avatar
Opening a frame
We have our new Flagstaff a frame but do not have a level spot to park it, so it is parked on a slight leaning angle. Is it ok to open it when it is not parked level just for packing purposes ? I am concerned about the weight and pressure on the roof and side walls. We plan to fix a better parking space, but until then....thanks!
BTW....it really pulls nicely!
mollypcb is offline   Reply With Quote
Old 04-26-2016, 11:54 PM   #2
1A Camper's Avatar
"slight leaning angle." Should be no problem, but you could always get a couple 2x4 to park the low side wheel on so it is level.
If it at to much of an angle the Ice box may not work, if you do a pre cool down before camping.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 04-27-2016, 01:04 AM   #3
Bluepill's Avatar
When I have to open up on an unlevel (side-to-side) area, I find that I usually have to push up on the roof a bit from the inside to get the roof locks to engage. Otherwise, no problem.
2008 Itasca Meridian 37H
frame, a-frame
