Old 04-14-2016, 08:45 PM   #1
opening door to load things into A frame without having to open it up
Is it possible to open the door while the camper is closed (walls down) to put a few items in it? It seems the roof overlaps the top of the bottom half of the door and it wont open unless I set up the walls to the upright position.
Maybe there's a trick I'm not aware of. Sorry I'm new to this and this is my first camper, I'm sure I'll post plenty more questions as time goes on. I appreciate the responses from folks here with more experience than myself.
il Padrino is offline   Reply With Quote
Old 04-14-2016, 10:14 PM   #2
mudman2's Avatar
U can raise the roof panel a hair open the door and u should be able to crawl in. You'll be very limited as to what u can do. Don't forget to raise the roof panel to be able to close the door.
2019 microlite 25bds
2015 tundra
mudman2 is offline   Reply With Quote
Old 04-15-2016, 12:02 AM   #3
Raise roof panel enough so overhanging side of roof clears the top of door then you can open door. Make sure you open it enough so when you let roof panel back down it does not hit top of door. When you are ready to close door make sure you lift roof enough so door will clear the roof overhang when closing.
mzak is offline   Reply With Quote
door, frame, a-frame
