Old 07-21-2013, 06:33 PM   #11
Yukon Don's Avatar
Originally Posted by RascalRv View Post
Should you not have your stabilizer down first before opening the camper and putting up the walls?
Actually no. The conventional wisdom is to get your roof and walls up and then lower your stabilizers.
They can twist the frame just enough to cause problems opening the thing up.
Also -this bears repeating and I wish I'd been told this sooner than I was- DO NOT use your stabilizers to level the camper. You can really bugger up your frame doing that. Use levelling blocks (cheap) or a BAL leveller (not so cheap) -the stabilizers are just there to keep the thing from wobbling around like a trawler in a perfect storm once you're set up.
2009 Jeep Wrangler Unlimited
2012 Flagstaff T10RD
Yukon Don is offline   Reply With Quote
Old 07-21-2013, 06:42 PM   #12
Good too know about putting walls up first before putting down stabilizer jacks.
SurveyorWI is offline   Reply With Quote
