Old 07-20-2013, 03:22 AM   #1
Other Newbie
Just got my new 2014 Flagstaff 19SCHW. Ok what I am doing wrong, when I try to push the first side up it want close all the way so can push the hatch in place. The level shows the camper is level.
Larry T
Jasper GA
Treadahl is offline   Reply With Quote
Old 07-20-2013, 06:10 AM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
Welcome
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-20-2013, 07:58 AM   #3
Did the roof at the peak engage before you raised the side? When you raise the door side first, you should only latch 1 side until you raise the far side and latch both.
Maverick
Maverick is offline   Reply With Quote
Old 07-20-2013, 08:37 AM   #4
I have to apply a significant outward push to get the side panels in place so the latches can engage. The seals on the side panels are just that tight. It is annoying, but the latches will close and with enough pressure.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 07-20-2013, 08:42 AM   #5
Welcome to the forum and congrats on your 2014 Flagstaff 19SCHW.
Old 07-20-2013, 08:54 AM   #6
Welcome from Dawsonville, GA! Enjoy your new camper!!
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 07-20-2013, 10:16 AM   #7
Thanks guys I'll check the roof again and then give it a hard push to see if that does the trick
Larry T
Larry T
Jasper, Ga
Old 07-20-2013, 10:41 AM   #8
handbuilder's Avatar
Larry, I use a small stool to stand on to give me leverage to push up. Sometimes I also push andget about 7/8 up and step to the left and finish lifting from the left. It doesnt.matter to me that I cant always raise it on one side with one push. Sometimes I can but most of the time, I dont...I start to the right then shift to the left and always use the small step stool cuz to most people, at 5'4", I am considered "short". haha
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 07-21-2013, 09:23 AM   #9
Yukon Don's Avatar
Larry, by any chance do you have your stabilizers already down when you're trying to open up the unit?
2009 Jeep Wrangler Unlimited
2012 Flagstaff T10RD
Yukon Don is offline   Reply With Quote
Old 07-21-2013, 04:22 PM   #10
Should you not have your stabilizer down first before opening the camper and putting up the walls?
SurveyorWI is offline   Reply With Quote
