Old 04-23-2015, 12:01 PM   #1
Mountain Goddess
Outlets don't work
Hello!
I have T12RB Flagstaff A-Frame. I did a stupid thing and hooked up the water (outside source) not realizing the interior sink faucet was on. Didn't realize it until the storage area under the double bed had about an inch of water. Dumb! Anyway, it's all drained and dried out but now the interior and exterior outlets don't work and the frig had to be switched to propane. The microwave, stereo and inside/outside lite works fine. There are 2 inside and 1 outside outlet. I checked the outlet by the frig and water heater, too. None have a reset button.
Any suggestions would be much appreciated!
Thank you!
Annabanana is offline   Reply With Quote
Old 04-23-2015, 02:02 PM   #2
First make sure that everything is dry. Check the breakers on your converter to see if any have tripped. I would reset them all. There should also be a GFRI outlet somewhere in the camper that control all the 110v outlets. Find that and reset as well.
The 12 volt is a different animal and separate from the 110.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 04-23-2015, 04:36 PM   #3
Mountain Goddess
Thank you, Archicamper! That worked. I did find the reset outlet under the dinette - didn't see it before as I was expecting a red reset button and it is black. For future reference, can you tell me where the converter is? I searched the Forum but didn't see it. Thank you again!
Annabanana
Old 04-23-2015, 04:40 PM   #4
I'm sure someone with an A-Frame will chime in but, it should be low to the floor maybe near the refrigerator. There should be a panel on it that opens to reveal circuit breakers for the 110 side automotive type fuses for the 12 volt side.
Old 04-23-2015, 10:27 PM   #5
handbuilder's Avatar
Anna, here is where the converter is in my A-Frame. It's the black looking square door under the dining bench, between the electric outlet and the water heater switch. Push the door in and it opens to reveal the breakers and fuses
ID:	75081   Click image for larger version
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 04-24-2015, 11:40 AM   #6
Mountain Goddess
Thank you, Handbuilder! Thought that might be it but couldn't figure out how it opened.
Thanks again, everyone! What a great Forum this is!
electrical
