Old 04-07-2014, 08:22 AM   #11
handbuilder's Avatar
I used WD40 and wiped any excess
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 04-07-2014, 08:34 AM   #12
WrongWayRandall's Avatar
Ours are silent at the moment, but a waterproof grease might work well. Just be sure that you wipe any excess with a rag so you don't get it on anything (like you!) in the event of contact with the hinge.
I've used white lithium spray grease in other, similar applications and it works quite well. It can be found in most automotive stores, or a hardware store if you still have one in your town. I suspect that the big box stores also would have this type of lubricant.
- Randy
1975 Westfalia (VW)
2014 Rockwood A122
WrongWayRandall is offline   Reply With Quote
Old 04-07-2014, 09:02 AM   #13
Thanks, I was going to do some spray silicone, but figured I would check to make sure if there was any recommended method. I wasn't sure how well the spray would work its way in.
loki008 is offline   Reply With Quote
Old 04-07-2014, 09:03 AM   #14
I prefer spray silicone to grease or oil based lubricants. Use a small amount and work the hinge a few times while the propellent evaporates. As with other lubricants, guard against overspray on fabrics.
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-07-2014, 01:03 PM   #15
OutAndAbout's Avatar
I used spray silicone and it worked. As with any lube you might have to reapply now and then.
Never try to teach a pig to sing, it's a waste of time and annoys the hell out of the pig.
2014 Rockwood A122S
2014 Tacoma 4x4
OutAndAbout is offline   Reply With Quote
