06-22-2015, 01:44 PM
#21
Mike, the placement of your velcro strip is much lower than where mine is. Maybe that is the problem? Look how much higher mine is attached, well above the hinge mechanism and roof trim. It could be simple physics of less "pull away" on the cloth of where it's placed flatter than at an weighted angle?
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
06-22-2015, 01:58 PM
#22
The velcro attachment is placed higher on my trailer than what is shown in Mike's trailer. It's a few inches above the hinge plate/trim, at the lower part of roof panel (not on the edge end).
06-22-2015, 02:08 PM
#23
Just to clarify, the Velcro sticks onto the white roof about an inch above the hinge.
Mike W
2015 T21QBHW
2011 Honda Pilot
06-22-2015, 03:42 PM
#24
Right, that's what I am saying... mine measures 5" above. Maybe before you make holes in the roof panel, you just adjust to attach a little higher? It's worth a shot before resorting to more aggressive attachment methods.
06-22-2015, 04:19 PM
#25
At least u have Velcro. Mine is basically attached with sticky tape that doesn't stick.
06-22-2015, 04:33 PM
#26
Lol Mudman! That's awful! (Regarding your name - Are you a potter?)
06-22-2015, 06:16 PM
#27
Not a potter. I was a tile contractor and mud floors were a type of installation. Therefore the name.
09-06-2015, 01:29 PM
#28
Just read through this thread as the cloth covers on my 2014 A-122S also come unattached. So, has it worked to apply stronger Velcro higher on the wall panels for those with this persistent issue?
Also, do you also have to replace the Velcro on the fabric ~ or only on the walls?
I'm wondering if SuperGlue might be a solution? Does anyone have feedback on this idea?
Thanks!
PegKen
09-06-2015, 03:16 PM
#29
Keep sticking it back up when it falls. Every time I open my camper it's down on one side , the bed side. Once I stick it back up it usually lasts thru the camp out. 3 to 4 days.
2019 microlite 25bds
2015 tundra
09-16-2015, 10:26 AM
#30
World Traveler Member
Originally Posted by abdiver
The Velcro used inside my 2014 trailer does not stay on. I just ordered a roll of commercial grade Velcro that came in 2' width and I cut it in half and replaced most of the Cheap stuff FR used and it seems to be holding strong now. It was $20 on Amazon, Home Depot has it also but only in Black and I ordered it in White online and it was cheaper.
I did order the commercial grade Velcro from amazon in white and put it on and it lasted months and now is falling off again. I even tried epoxy on the ends but no help. I am about to resort to small screws on the ends and middle since nothing stays on for long.
2014 A194HW
2004 Toyota 4runner V8 4WD
09-22-2015, 08:27 AM
#31
I had pressure washed off the velcro on the outside for the screen room and instead of putting new on I used my 3M 77 spray adhesive to the back of the tape and reapplied . The velcro is now on like gang busters and has made numerous washes - the pressure wash really cleans out the hook strips that get dirty and filled with stuff .
09-22-2015, 08:58 AM
#32
Thanks, I'll try it and report to the thread. Have hesitated using screws, but did try a staple gun and it worked, but now sure I want holes of any size in the roof. We've heard enough about leaks, and don't want to temp the water gods.....
Mike W
2015 T21QBHW
2011 Honda Pilot
07-23-2016, 04:31 AM
#33
Originally Posted by kdot
Same problem with my roof hinges. The front curtain has held up; the rear one kept falling off. I finally put a few small, short screws through it and it has held up fine since then.
Kent
Kdot.. how are the small screws, in the roof panel, working out at holding the hinge cover valance?
Did you run the screws through the velcro strip.. then attach the valence to the velcro? Or just screw through the valance fabric directly to the roof panel?
What size screws work safely? Do not want a hole through to the outside.
Thank you.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
07-23-2016, 07:22 AM
#34
We had the same problem, just on the table side. I replaced the Velcro strip and cleaned the surface thoroughly with alcohol first. It has stayed so far, but if it comes down again, I will probably go with stapling it up. I think the heat changes really are just too much for the adhesive on the Velcro. If that is our only issue I will be very happy!!!!
Molly
Flagstaff T12BH A-Frame 2016
2006 Toyota Tacoma 4X4
07-23-2016, 07:31 AM
#35
Poor Velcro Used in Trailer
Chuck9997. Can't tell you exactly what size screws I used, but they were long enough to get through the fabric, two layers of velcro, and the thin piece of metal on the back wall of the trailer, and wide enough to hold in place. I put the valence in place on the velcro, then carefully drilled through the whole thing until the drill popped through the wall surface. You need to run the drill slowly so as not to wrap the valence material around the drill bit. Then just screw the whole thing down until snug. I think I used about 5 or 6 self-tapping screws. Don't snug the screws down too tight or you'll strip the hole and have to drill another one. After I did this, the valence never moved again. Hope this helps.
Kdot
2019 Flagstaff E-Pro 19FBS
2017 Honda Pilot
07-23-2016, 07:37 AM
#36
the velcro problem is not limited to A frames, the velcro is so small and ineffective on my dinette cushions they slide all over the place.
Retired Navy
2016 Flagstaff 26 FKWS
07-23-2016, 10:24 AM
#37
I use this out here in Vegas with our extreme heat. 170+ inside vehicle during summers.
http://www.scotchbrand.com/3M/en_US/...4603615&rt=rud
Works great! It holds my brake controller to the lower dash without falling off. Don't even have to use a lot- really good locking strength.
I did prep with 3m adhesive promotor. Local auto parts stores sell them. Looks just like alcohol towelettes. It makes the surface tacky.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
07-23-2016, 12:13 PM
#38
Originally Posted by HONDAMAN174
Seems your link goes to an "ERROR" page.. what is the name of the product you used?
07-23-2016, 12:43 PM
#39
Poor Velcro used in my Trailer does not stay!
Sorry about that. They are scotch brand all weather fasteners. All plastic interlocking teeth. They come in four inch strips and got mine at target.
Funny- I just clicked it from your post and mine and it works. Oh well
07-23-2016, 01:02 PM
#40
Yea.. works now for me too. . Damn computers.
