Old 09-23-2011, 02:49 PM   #1
Pop ... goes the water heater ...
My full gas water heater seems to have ignition problems, and need to know if anyone else is experiencing this .. cause this is my first trailer with this option.
The gas is turned on, to the one one bottle i wish to drain. I open the propane tank, and then go inside and flick the switch for the ignition for the water heater. - all this ofcourse after I have purged the water lines of all air.
Anywhoooo .. the ignitor comes on for at least 2 full rounds, before i hear an "explosion of sort" just at the door of the WH. I am assuming this is not normal .. and has happened now twice in a row when I start the system up cold ... and now its happening when it has been running, and comes on during the night to warm the water. The ignition of the WH wakes up the dog. I shut it down on my last trip .. because i think there is something "amiss".
The unit will be going in for its first warrenty service in the next few weeks, and I know this will be covered ... but if anyone has an explaination, it would be most appreciated.
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 09-23-2011, 02:57 PM   #2
cebaker's Avatar
Mine does that too. I don't know why. So I just started using the heating element. Saves on gas. And a lot more quiet. Hopefully somebody will help us.
2010 Toyota Tundra
Forest River 32vbhs
cebaker is offline   Reply With Quote
Old 09-23-2011, 03:05 PM   #3
First thing I would do is remove the burner assembly and give it a good cleaning.
latner is offline   Reply With Quote
Old 09-23-2011, 03:13 PM   #4
yea ...
Thats what i thought too .. but being that its under warrenty i think i will let someone else check it out .. while doing the rest of the work required.
im thinkin thats most likely where all this problem stems from .. spiders in the venturie ... after all .. its only 3 months new.
d-mo
2011 Rockwood A122
Old 09-23-2011, 04:36 PM   #5
DAISY BOYKIN's Avatar
Check burner tube
Check your burner tube for a spider or bug, does happen you know!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 09-23-2011, 05:01 PM   #6
TURBS's Avatar
I think the flux capacitor might have a short !
Sorry I am just in one of those moods today !
Old 10-02-2011, 04:02 PM   #7
So, is it 'normal' to make a loud noise when the wh is running? It was the middle of the night. It almost sounded like we had a major water flood issue. Checked it all out and could not find a problem, just a loud roar.
ckhomes is offline   Reply With Quote
