Old 06-26-2014, 10:54 AM   #1
Propane tank switch valve question
Since I'm on the forum, I have a simple question. I noticed the tank selection switch. If the selected tank runs out, will it draw from the other tank automatically? or do I have to switch it manually?
99 4runner
T12BH Aframe
68Triumph is offline   Reply With Quote
Old 06-26-2014, 10:59 AM   #2
Old Enough to Know Better
gasman6674's Avatar
All the switch/lever does is change the "indicator" the regulator will switch and draw from the reserve tank. Flip the "switch" and then refill empty and you are good to go
Hope this helps
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 06-26-2014, 06:00 PM   #3
Mostly Harmless
thehamguy1's Avatar
You have to switch it manually unless the regulator knob is set to draw from both tanks at once, which is the middle position. That's not recommended because when you run out, you're completely out. Gassman's right, when one tank is empty, open the other tank's valve, turn the knob on the regulator to that tank before you unfasten the empty one, (that way no air gets in the line), and keep on cookin'.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 06-26-2014, 06:05 PM   #4
fonzie's Avatar
If you have an auto switching valve it will do it automatically if both tanks are open. Some are manual and you have to do it manually....if you have this type it is auto...
When middle indicator show red (here orange) it means that you have to switch the indicator to proper tank, but the gas part switches automatically.
Name:	Propane auto switch over.jpg
Fonzie
propane, tank
