Old 10-23-2015, 02:02 PM   #11
World Traveler Member
abdiver's Avatar
Originally Posted by JoArt View Post
Itís been a while since we ďdry campedĒ in our Rockwood A frame. Itís equipped with both 12 & 120 electric and propane refrig.
Q: Does generator automatically override propane refrigerator? Or do we have to turn off propane & relight it every time we run electric gen?.
Thx, J.
Mine does if I have the refrigerator set to "AUTO" and every time I start my generator for the microwave the Refrigerator switches to electric. If my refrigerator is set to "GAS" it stays on propane and does not switch.
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
Old 10-23-2015, 02:29 PM   #12
bikendan's Avatar
The OP is talking about 3-way fridge, NOT a typical 2-way fridge.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-23-2015, 02:34 PM   #13
TURBS's Avatar
Got it
Old 10-23-2015, 03:19 PM   #14
Unless the OP has a High Wall model, the standard height A-frames have small 3 way fridges with the following "features":
- there is no "Auto" or "Automatic" setting. You must individually turn on/off/start the desired mode - 120V AC, 12V DC, or propane. In most of the standard A-frames, the AC and DC on/off switches are behind the upper outside panel, and the propane valves and starter are behind the lower outside panel.
- all modes are continuous run. The fridge runs continuously until the power or propane runs out or is shut off. Temperature regulation is by varying the gas flame with a valve (propane). On AC, newer fridges of this type have a control that functions just like a house light dimmer, changing the power to the AC resistance coil. DC is unregulated on these fridges. As a result, it takes some fiddling over several days to get a constant temp inside the fridge.
- no inside controls. All controls and switches are accessed from the outside vent panels.
Before camping: 12-36 hours prior to departure, trailer is plugged in, fridge set to max on AC. When hooking up to depart, trailer unplugged, fridge switched to DC. Tow vehicle powers fridge (5-6 amps) and keeps batteries at full charge. Propane does not stay lit for me on the road, and there is no auto-restart. At camp, switch to AC or propane depending on power. Set to one number below max cool. After 2 days camping, dial cool back to about 2/3.
Fred W
Now: 2014 Rockwood A122 A-frame (12ft box)
Then: 2000 Coleman Westlake PUP (12ft box)
Now: camping Colorado and adjacent states one weekend at a time
Then: 10 days at Lake Tahoe each summer plus occasional weekends in California
Old 10-23-2015, 05:17 PM   #15
abdiver's Avatar
Fred W
I do have the HW and three way fridge A194HW and I use the Auto most of the time. I am not aware of the 2 way fridge, thanks for info.
2014 A194HW
Old 10-23-2015, 10:16 PM   #16
A32Deuce's Avatar
One thing I learned from someone that rents out RV. That is, don't run fridge on auto when traveling. Leave on gas till set up with shore power, then switch. He said traveling and running gen. for a few minutes for micro, does small damage to electric side and gives problems later. Gets worse a little at a time.
A32Deuce is offline   Reply With Quote
Old 10-28-2015, 11:18 AM   #17
Thank you all for your info on propane switch. It seems our 2012 Rockwood does need to be manually switched 12V to propane or vice-versa. All your comments helped on our recent weekend trip of "boon-docking".
JoArt is offline   Reply With Quote
generator, propane
