Old 04-22-2016, 09:00 AM   #1
kdot's Avatar
Raising the HW roof
If the actuator on the HW model A-frames fails while camping, can the roof be raised manually? How difficult is it? It really seems to strain that little actuator when it's being raised.
Kdot
2016 Rockwood A 213 HW
2016 Honda Odyssey
kdot is offline   Reply With Quote
Old 04-22-2016, 09:04 AM   #2
OYO
OYO's Avatar
Kdot
You have to disconnect the connecting rod that goes from the motor to the roof section. Best to secure it with a wire tie if you plan on leaving it unattached
OYO is online now   Reply With Quote
Old 04-22-2016, 09:35 AM   #3
kdot's Avatar
Raising the HW roof
OYO, thanks for the reply. I know it has to be disconnected; I guess I didn't make that clear. What I want to know is: from those who have had to raise the HW roof manually, once the actuator is disconnected, how hard is it to raise that roof? It looks like it would be a beast to do. Is it?
Kdot
2016 Honda Odyssey
Old 04-22-2016, 09:52 AM   #4
It is all about leverage and upper body strength. Pushing up near the middle of the trailer will help decrease the effort needed. The closer you are to the back of the trailer while pushing, the more effort needed. A small ladder will help, as will having someone help push up from the other side of the trailer.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 04-22-2016, 02:25 PM   #5
Opening the camper door before lifting will allow better airflow into the camper and make that initial push up much easier. So will having another person on the front handle.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is online now   Reply With Quote
Old 04-23-2016, 07:58 AM   #6
kdot's Avatar
Raising the HW roof
Thanks Big Vic and Pooneil. From what you guys wrote, it sounds like the job should be pretty difficult, but could be done with help.
Kdot
2016 Honda Odyssey
Old 05-04-2016, 11:15 AM   #7
My actuator broke on our first trip, I disconnected it with an adjustable wrench and lowered it manually. I can raise and lower it by myself fairly easily, but I'm 6' 2". Has anyone replaced the actuator themselves? I don't want to waste a camping weekend driving to the dealer.
dissident5 is online now   Reply With Quote
Old 05-04-2016, 02:15 PM   #8
kdot's Avatar
Raising the HW roof
Dissident, was it easy because you're 6'2", or because you're exceptionally strong? I'm 5'11" and pushing 80. If it was easy to do because of your height, then a ladder ought to do it for me. If it was because you're exceptionally strong, then I might have a problem doing it that I wouldn't have had when I was younger!
Kdot
2016 Honda Odyssey
Old 05-04-2016, 03:17 PM   #9
I think it's more height/reach than strength. I start with the handle on the side until I can get in and then push up on the roof the rest of the way. I would say I have average strength for someone around 40.
Old 05-04-2016, 03:39 PM   #10
World Traveler Member
abdiver's Avatar
I use a step stool and also have my wife give a starting push on the other handle and it is not too bad. I am 5'9" and I have notice it does lose it spring tension with age same as me!
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
roo, roof
