Old 09-15-2014, 10:52 AM   #31
Alternate receptacle clearance solution
I found that there is enough clearance to plug in a 90 degree plug extension cord into the 2 receptacles next to each end of the bed.
These are available online and in some hardware stores -
Rotating 90 Degree Flat Plug Power Extension Cord Power Cord Adapter
A power strip can then be plugged into the adapter.
mickrock is offline   Reply With Quote
Old 09-16-2014, 07:01 PM   #32
Another LED light mod
I borrowed this idea from another post.
The light string is from ebay, and only $7.
New Cool White 5M 300Leds Non-Waterproof SMD 3528 Flexible Led Strip Lights
The only glitch is that a power supply, also sold by the same vendor for 12v dc, is needed if you intend to use 115v ac to 12v dc power for the led lights. The light string extends a few inches below the bottom of each "A", and has a super dynamic look.
A strong adhesive is on the back of the light string. The picture does not really show it as good as it actually looks, and my efforts to edit it did not come out well.
Old 09-19-2014, 03:59 PM   #33
You can also get a nice little dimmer switch for it so you can adjust the intensity to your liking. I think the inline dimmer was only a few dollars.
2011 A-122
rawlus is offline   Reply With Quote
Old 11-08-2014, 11:59 PM   #34
Great idea!
Kanikamom is offline   Reply With Quote
a-frame, frame
