Old 08-10-2012, 06:25 AM   #1
FarFromStock's Avatar
Removable tables in A-frames
Has anyone found a good source for the removable tables for the A-frames? The dealer quoted over $50 for a single removable table, and I am really hoping that these tables can be found for less.
If anyone has information, please share!!!!
Thank you!!!
Debbie
...and...we're camping!!
Glenn & Debbie
2013 Rockwood A127TH (aka Carl)
2012 Ford Raptor
Camping born-on date: 21 July 2012
Nights camped: 2014-3 (so far!!); 2013-16; 2012-2 nights
FarFromStock is offline   Reply With Quote
Old 08-10-2012, 07:01 AM   #2
Thank you!!!
Debbie
You might consider going to a much lighter table and cutting wooden slats for bed use.
What I did to resolve the table issue is included in the following video.
Dave
Currently trailerless.
2014 Silverado Double Cab 1500 5.3L V8 w/3.42 Axle Ratio Tow Vehicle
Sold: 2012 Rockwood A122 Hardside Popup
daveinpickerington is offline   Reply With Quote
Old 08-10-2012, 08:21 AM   #3
What I did was take an old kitchen cabinet and put a drawer under and made a little table to go on top of it. Because I had most of the things that I needed to make this it cost me very little, less than 5 dollars. I mounted it with 4 drywall screws......so far it works great.
cleancut39 is offline   Reply With Quote
Old 08-10-2012, 09:49 AM   #4
handbuilder's Avatar
Hi Debbie - Are you talking about this removeable table? I cant see paying more than 50- for something this simple...it may be less expensive if you make yourself - youd just need to find the hardware (prob online, if cant be found locally)
ID:	17805   Click image for larger version
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 08-10-2012, 10:14 AM   #5
Rockwood Premier A126
gregory's Avatar
The removable dining table, that came with our aframe, is terribly heavy and pretty awkward. We never use it and do not pack it along anymore. If it's in-climate weather and we need eat inside our aframe, we use folding TV trays. I'm liking daveinpickerington's table in his vid. It looks like it would be a great choice for us too!
We are even considering alternates to the hang on tables as well, because of their weight and the material they are made of. It's a hassle to remove them each night in fear of dew or rain ruining them. I thought about using a staple gun to attach plastic table cloth material over the top, but that would get ratty over time...So, with using the hardware in mind, I want to dream up different table top material alternatives. We just haven't had time to implement any ideas for this project yet, let alone go camping...darn work gets in the way of all our fun!
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 08-10-2012, 10:55 AM   #6
Yes, Tamara, that's the one. We actually like having that as opposed to the larger dinette table. And, as Deb mentioned, we are actually considering leaving the dinette table home when we go out.
Deb - I like the idea of using TV trays...hmmm...I'll need to mull that one over in my brain and see what the DH thinks too!!! Good idea on using a different material - maybe a thick plastic cutting board with the rails attached? Gosh...that may be my answer as well!!!
Thanks everyone for your inputs!!!!
Glenn & Debbie
2012 Ford Raptor
Old 08-10-2012, 11:07 AM   #7
gregory's Avatar
The draw back to using the light weight (old fashioned metal) type of TV tray is it wiggles when you cut your food. The wood ones are better in that regard, but again they have a little more weight, but not as bad as the original table.
Yes the plastic cutting board, or something along those lines, sounds promising for the hang on table tops. hummm...
Deb
Deb & Gary
Old 08-15-2012, 09:37 PM   #8
We use a Wal-Mart folding table inside and out. One of the first things I did was remove the mount from bottom of the table and also in the floor. We slide the modified table under a seat cushion when not in use for the bed. We also don't trip over the factory table's floor mount. I used the table and floor mounts to add a grill table in the pontoon boat. My next door neighbor is a cabinet maker and gave us a large piece of solid surface countertop that was from a kitchen sink cutout. These sink cutouts are waste and a cabinet place will give you one. They make great sag proof , burn proof, and great looking, table.
CCrane2299 is offline   Reply With Quote
Old 09-09-2012, 01:05 PM   #9
Deb
Remade the inside table out of plywood at a shorter width and use a matching board to fill the space if we need it as a bed. Got rid of folding legs in favor of pedestal for lighter weight and more legroom.
Outside table, salvaged hardware, bought nice bamboo cutting board at home goods in sale and attached j-hook hardware to that, much more durable, attractive and will hold up to getting wet.
2011 A-122
rawlus is offline   Reply With Quote
Old 09-09-2012, 08:53 PM   #10
gregory's Avatar
Sounds good! Thanks for the idea.
Deb
Deb & Gary
a-frame
