Old 09-20-2016, 02:07 PM   #1
Vinnie's Avatar
Removal of Water Filter
After reading several post about the in line water filter in the A-frame and the trouble I had removing the canister I decided to remove the filter and canister and connect the water line with a 4 inch piece of sch 80 grey pvc pipe. I noticed on the small piece of pvc pipe it said for "Outdoor Use Only" has anyone come across this? Does that mean it cant be used with portable water? I bought it in the sprinkler section of the hardware store.
________________
Rockwood A214HW
Vinnie is offline   Reply With Quote
Old 09-20-2016, 09:16 PM   #2
It is safe for cold water lines only.
ww.todayshomeowner.com/are-plastic-water-pipes-safe/
2012 Rockwood a124
mzak is offline   Reply With Quote
Old 09-21-2016, 01:34 PM   #3
Vinnie's Avatar
It should be ok then its connecting the line on the fresh water side before it makes its way to the water heater.
________________
Rockwood A214HW
water, water filter
