Old 07-12-2019, 07:43 PM   #1
Remove ceiling light cover
I have a 2016 213hw. One of my ceiling lights is flickering so Iím trying to remove the cover to check bulb or wire
Canít get the darn thing off. I see the 4 little notches, but no reasonable amount of squeezing or prying is doing it
How is this done? Does just the clear part come off or the whole thing?
Appreciate your helpClick image for larger version
mtmurphy56 is offline   Reply With Quote
Old 07-12-2019, 08:26 PM   #2
Just the clear lens.
Slide a thin knife in between the lens and the white outer housing.
The lens will pop out as you pull/pry down on the knife.
The notches will fool you!
Also, if LED, it 'may' have a wafer type bulb. Most are non-replaceable. New light or solder in a new wafer.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 07-12-2019, 08:37 PM   #3
Thanks so much. Iíll try that
Old 07-13-2019, 02:39 PM   #4
Ok I got the cover off. Turns out it is not a replaceable bulb, but I found a replacement fixture in Amazon. Thanks for your help.
Old 07-14-2019, 03:17 PM   #5
The clear lens removes easily with a paint can opener. Less than a $1 at Lowes
RStormC is offline   Reply With Quote
Old 07-14-2019, 05:14 PM   #6
What was Amazon item number?
Do you have a link to the replacement fixture or an item name/description? I have an A214HW and it would be helpful to know. Thank you.
Chewy2 is offline   Reply With Quote
Old 07-14-2019, 07:09 PM   #7
Facon Classic Style LED 12V Bright Pancake Light Interior Ceiling Dome Light 7W 500 LM with On/Off Switch for RV Motorhomes Camper Caravan Trailer Boat https://www.amazon.com/dp/B06XR7LNY2..._1p8kDbBF58420
Old 07-14-2019, 09:56 PM   #8
Thank you very much!!!
Chewy2 (used to be Sam2jack)
Rockwood A214HW (2018)
Nissan Frontier SV6 4x4 (2017)
Old 07-15-2019, 06:01 PM   #9
JArry's Avatar
It's only one light flickering?
If both lights flicker, just a tip for you or future searchers: In case you're not aware, the ceiling lights are wired with a switch that turns them off when the roof is lowered. Mine is located at front left of the interior behind the fabric "curtain." Sometimes the switch sticks and I have to push it in (and let it spring out again) to allow me to turn the lights on.
Might be worth checking that as a possible cause.
2016 Flagstaff T12RBST A-Frame (same as Rockwood A122S) | 2006 Honda Ridgeline RTL
Nights camped in 2016: 37; 2017: 52; 2018: 47; 2019: 57
JArry is offline   Reply With Quote
Old 07-16-2019, 09:08 AM   #10
Thanks JArry. It was just the one light. I replaced it and all is well. Thanks for the tip for future reference
Old 07-23-2019, 04:11 PM   #11
FremontBob's Avatar
Just replaced one also
Thanks for all the guidance. One of mine went out, when I removed the Dome I felt pretty stupid, no bulb but a soldered panel, etc. Just replacing the entire unit was easy and there is light. One thing to note, the lumens are 470, so if you are looking for 500, stop. They round up.
FremontBob is offline   Reply With Quote
cover, light
